Author Topic: Front brake pad replacement  (Read 2943 times)
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
« on: March 14, 2016, 02:12:06 PM »
Replaced the front brake pads on my 2001 C10 after about 90,000 km. I guess I ride more than brake.
If you remove the smaller pad and remove the spring thingies at the side (Spring, Pad Stopper #92081), you can push the caliper holder (Holder Comp Caliper #43044) in all the way.
Then you can tilt the larger pad a bit and slip one end off. After that, the other end is a breeze.
For carrier pin lube, I wanted something waterproof that would tolerate high temperatures, silicone-based so the rubber bits don't swell up. In the US, that's readily available (Sil-Glyde) but in Canada, not so. Ended up using dielectric grease from Canadian Tire which meets all the criteria.
« Last Edit: March 14, 2016, 05:34:12 PM by George R. Young »
Offline Strawboss
Re: Front brake pad replacement
« Reply #1 on: April 10, 2016, 09:54:38 AM »
Thanks, I'll remember to do this, I just got replacement rotors and pads from Murph, now I just have to wait for it to stop snowing so I can work on the bike. ;D
Offline Daytona_Mike
« Reply #2 on: April 20, 2016, 09:36:45 PM »
Thanks George. Nice write up.
 I been using SuperLube Silicone grease as it has PTFE (slippery) and its made for use with rubber.
