Author Topic: Tip over bars  (Read 8681 times)
Offline DC Concours
  • 2001 Concours, ~35K miles
Tip over bars
« on: February 12, 2016, 12:34:52 PM »
Anyone here with the RIVCO tipover bars can recommend if I can get/make the other spacers and bolts from home depot?
I just need a few extra parts...few spacers and bolts.
All I received is shown in the pic.
Offline ManWorkinghere
    • Avatar database
Re: Tip over bars
« Reply #1 on: February 24, 2016, 11:39:42 AM »
I see you received good replies over on the other COG board.  I hope your work is going well.
Offline DC Concours
Re: Tip over bars
« Reply #2 on: February 24, 2016, 01:09:09 PM »
Yes, good advice.
I have gone to homedepot and found pipes for spacers. Just deciding between using steel or an aluminium pipe.
Offline oldsmoboat
Re: Tip over bars
« Reply #3 on: February 24, 2016, 05:14:38 PM »
I have a brand new set sitting here in front of me, still in the box.  Let me know if you need a pic or anything.
Offline DC Concours
Re: Tip over bars
« Reply #4 on: February 24, 2016, 05:44:39 PM »
you want to sell some pieces out of that box? :D
Offline oldsmoboat
Re: Tip over bars
« Reply #5 on: February 25, 2016, 06:11:13 AM »
LOL
I assume I will need them all.
Offline DC Concours
Re: Tip over bars
« Reply #6 on: February 25, 2016, 09:17:40 AM »
Just thought I would try!!
I don't need anything just yet. Perhaps the lengths/specs of those bolts would be helpful if you have them.
Offline oldsmoboat
Re: Tip over bars
« Reply #7 on: February 25, 2016, 03:28:47 PM »
Which bolts?
Offline DC Concours
Re: Tip over bars
« Reply #8 on: February 25, 2016, 03:33:19 PM »
The 3 sets of bolts in the pic., when you have some time. I need to hunt down these bolts at the local hardware store.
Which bolts?
Offline oldsmoboat
Re: Tip over bars
« Reply #9 on: February 25, 2016, 04:01:06 PM »
2 @ 3/8 X 5 Grade 5
2 @ 3/8 X 2.75  Not sure of grade, says TVS and 10.9
4 @ 7/16 X 1 Grade 5
« Last Edit: February 25, 2016, 04:38:28 PM by oldsmoboat »
Offline DC Concours
Re: Tip over bars
« Reply #10 on: February 25, 2016, 04:04:21 PM »
You are fantastic! :hail: Thank you.
Are these bolts steel?
Offline oldsmoboat
Re: Tip over bars
« Reply #11 on: February 25, 2016, 04:08:20 PM »
Yes, black oxide.
Offline DC Concours
Re: Tip over bars
« Reply #12 on: February 25, 2016, 04:15:23 PM »
Do you have 4 of the little 1" bolts?
The middle pair (2.75") is likely metric since it goes into the bike. Maybe M10.
How do you (would I) know the grades? Are the grades stamped on the bolts?
Offline oldsmoboat
Re: Tip over bars
« Reply #13 on: February 25, 2016, 04:34:48 PM »
They may be metric, I don't have anything to measure metric.  The grades are in the post with the sizes.
It came with 4, 1" bolts.  1 was hiding.
There's this too.
http://www.rivcoproducts.com/instructions/download/KAW050_booklet.pdf
http://www.rivcoproducts.com/instructions/download/KAW051_BOOKLET.pdf
Offline DC Concours
Re: Tip over bars
« Reply #14 on: February 25, 2016, 07:01:01 PM »
Thank you sir. you have been very helpful.
when are you going to install yours?
Offline Deziner
  • Phoenix
Re: Tip over bars
« Reply #15 on: February 25, 2016, 10:04:13 PM »
I'm thinking those are actually 10mm and 12mm bolts. Thread pitch doesn't look like Americanese.
Offline oldsmoboat
Re: Tip over bars
« Reply #16 on: February 26, 2016, 01:31:27 PM »
Probably in a week or two.  I have a looooooooong list.
Offline DC Concours
Re: Tip over bars
« Reply #17 on: February 26, 2016, 01:44:43 PM »
Me too. After I make the spacers and find all the bolts.
Give the rest of us some fyi pointers after you install.
