Author Topic: Stant Thermostat  (Read 4069 times)
Offline KZBell
Stant Thermostat
« on: June 25, 2011, 06:25:06 AM »
If someone in the know can tell me if this is the right part number for 1987 Connie and if it is possible to change the thermostat without removing the carbs....Thanks.
Stant thermostat p/n 13368
Certified Zip-Tie Mechanic
Offline dbethel
Re: Stant Thermostat
« Reply #1 on: June 25, 2011, 10:44:32 AM »
No need to pull the carburetors just to replace the thermostat, I have R&R'd the thermostat housing 20 odd times since new (2005).
D.
Offline Intruder
  • All Weather Medium Attack!!!
« Reply #2 on: June 25, 2011, 10:44:36 PM »
Stant 13368 is the correct substitute for the Connie Thermostat according to the chart I have.
Jim
AECS US Navy Retired
1984 Honda VT500 Ascot
Offline KZBell
« Reply #3 on: June 26, 2011, 06:04:21 AM »
Thanks for the replies...despite proper levels bike has been running on the warm side so I figure I will throw in a new stat to see if that helps.
« Reply #4 on: June 26, 2011, 07:17:52 AM »
On an older bike it is also a good idea to replace the pressure cap too; they can leak by slighty at lower pressures thus causing the engine to run warmer without puking fluid out of the bottle.
Offline SteveJ.
« Reply #5 on: June 26, 2011, 09:15:20 AM »
To follow up on the old cap idea, my gasket on the cap had swollen enough that it would not release pressure.
America's Seaplane City
Offline KZBell
« Reply #6 on: June 26, 2011, 10:18:42 AM »
The cap looks to be in good shape but I will swap it out just in case since it's not something that will break the bank.
