Author Topic: Headlight adjust?  (Read 3159 times)
Offline timmerz
Headlight adjust?
« on: October 09, 2015, 04:00:50 PM »
Think I've done this before quite awhile ago, but for the life of me can't find the adjustment to raise the headlight angle up a bit...can anybody help with a pic?
Offline timmerz
Re: Headlight adjust?
« Reply #1 on: October 09, 2015, 07:07:17 PM »
Pic not necessary if somebody has done it and can explain...I think I see an adjustment thingy on the right looking up from underneath, will a large phillips do it? And, which way to rotate to raise the beam higher?
Offline Rick Hall
  • Eruption
« Reply #2 on: October 09, 2015, 10:29:45 PM »
Correct. Though I'm unsure which one is lateral and which one is vertical. And which way you turn :-/ The manual spells it out though.
The #3 phillips bit from the tool kit works peachy.
Best bet would be to put the bike on the centerstand 10-20 feet from a wall, easier to see the beam. Adjust as needed.
Rick
Addendum. The adjuster on the lower left side is up-down. The adjuster on the upper right side is left-right.
Offline timmerz
« Reply #3 on: October 09, 2015, 11:08:07 PM »
Awesome, Rick...thanks a mil!  8)
Offline timmerz
« Reply #4 on: October 10, 2015, 05:10:23 AM »
...aaaaaaand of course the high beam has to burn out on my way in to work at 12:30am tonight...
