Author Topic: Loose Front Fender  (Read 2668 times)
Offline oldsmoboat
Loose Front Fender
« on: April 03, 2015, 05:43:21 PM »
I bought the bike used so I am not sure how tight the fender should be.  I assume it shouldn't move.
Bolts are tight but there is slop in there.  I don't see any washer in the parts list.  I assume this isn't normal.
https://www.youtube.com/watch?v=gdYzCIuux_E&feature=youtu.be
http://www.partzilla.com/parts/search/Kawasaki/Motorcycle/2004/ZG1000-A19+Concours/FENDERS/parts.html
Offline turbojoe78
Re: Loose Front Fender
« Reply #1 on: April 04, 2015, 06:09:03 AM »
I haven't had this problem with mine but I've heard tell that there are some rivets that hold the mounting bracket to the fender and they can become loose over time.
Some have had luck with trying to tighten up the rivets with a hammer and a punch, and others have drilled out and replaced the rivets.
Offline oldsmoboat
« Reply #2 on: April 04, 2015, 06:45:43 AM »
Thank you
Offline connie_rider
« Reply #3 on: April 04, 2015, 08:38:42 AM »
Joe, told you right.
Tighten the fender at the rivets.
