Author Topic: Help oil leak  (Read 2458 times)
Offline Jet86
  • California
Help oil leak
« on: January 01, 2015, 05:25:06 PM »
This just started not long ago but i don't know what this part is but it has a allen slot and looks like that's where the oil is coming from, why? and how to fix? is there a failing gasket behind that?.
Offline gregman_1
Re: Help oil leak
« Reply #1 on: January 01, 2015, 07:34:36 PM »
That is a plug that retains the shaft that your cam followers pivot on.  There is an O-ring behind it (you should be able to get this from an auto parts store, or you can order it from the dealer, it's about a dollar and is PN 670)
The shaft is not going to come out when you remove the plug, but there will be a fair bit of oil that comes out.
2005 Concours-"The Other Woman"
Stock except Canyon Cages and heated grips
Offline Jet86
  • California
Re: Help oil leak
« Reply #2 on: January 02, 2015, 05:08:25 AM »
Thank you, i have a few more questions, witch way to turn the cap to loosen it, i some times forget and i don't want to strip or break something, And i could not find this part on Ron Ayers witch is where i normally look up parts weather i buy from there or not i like the fiche. could you provide a link to the part.
Thanks
Offline gregman_1
Re: Help oil leak
« Reply #3 on: January 02, 2015, 05:27:00 AM »
It's normal righty-tightey, lefty-loosey,
I didn't see it on Ron Ayers, but here's the part on Bike Bandit.  The plug is PN 92066, the O-ring is PN 670.
http://www.bikebandit.com/oem-parts/1994-kawasaki-concours-zg1000a/o/m150007#sch58074
Offline Jet86
  • California
Re: Help oil leak
« Reply #4 on: January 02, 2015, 05:47:16 AM »
I was looking in the wrong place, found it on Ron Ayers under valves http://www.ronayers.com/Valves-C407000.aspx
good to know bike bandit has it as well
Thanks for your help buddy
