Author Topic: New videos coming - can your c-10 do this?  (Read 27659 times)
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« on: October 27, 2014, 07:28:29 PM »
first, more in the pipeline. Post subject matter, maybe it'll make the cut  - steve
Concours ZG1000 - Can Your C10 Do This?
Offline Toxz Qwaste
  • stuff & things
Re: New videos coming - can your c-10 do this?
« Reply #1 on: October 27, 2014, 08:35:15 PM »
I just put her away for the season and started wondering what to do during the COLD DARK TIMES. Torque cams came to mind. Gunna see about finding some $$. Have you done a cam swap vid yet?
« Reply #2 on: October 28, 2014, 05:18:12 AM »
here ya go - Steve
    Concours ZG1000 Cam and Valve
Offline JDM
« Reply #3 on: October 28, 2014, 06:38:42 AM »
Let Steve do your carbs so you can take full advantage of the Torque Cams installation. I promise it will be the best money you ever spend on your Connie...........
Offline Toxz Qwaste
  • stuff & things
« Reply #4 on: October 28, 2014, 06:44:11 PM »
Thanks Steve. Great vid. Have you come across any followers that were no good for the new cam?
Then what am I going to do during THE COLD DARK TIMES?
Offline turbojoe78
« Reply #5 on: October 29, 2014, 06:30:18 AM »
Mine will idle that smooth at 1000 RPM's, it also idles that smooth at 500 RPM's but won't go any lower than that.
I can turn the idle adjusting knob counter clockwise bringing the idle down to 500 RPM's but continued turning won't get it any lower than that, it just continues to idle nice and smooth at 500.
« Reply #6 on: October 29, 2014, 08:18:13 AM »
and I know what cams / carbs you have too  :chugbeer: Steve
Offline turbojoe78
« Reply #7 on: October 29, 2014, 08:23:08 AM »
Disclaimer:  I have SISF's power cams, EX cam sprocket and right now the stock 32mm carbs with Steve's jetting.
Life is good ...  ;)
