Author Topic: Oil pressure switch  (Read 2174 times)
Offline blade
Oil pressure switch
« on: June 13, 2011, 04:21:32 PM »
It is looking like I have an issue with the oil pressure switch on the 92 I picked up. Thought it was the dish light to start with but after swapping the bulb and finding that the original actually works, I started looking at the switch itself.
Ohmed out the blue wire from the light to the switch terminal and it showed no break in the circuit. So the switch is pulled out and there does not seem to be any crap lodged in the hole.
Do I have to buy a mama K switch or is there a compatible switch available?
Thanks
Stan
