Author Topic: Petcock Question  (Read 3357 times)
Offline Chris Baum
Petcock Question
« on: March 09, 2014, 03:57:50 PM »
COG Nation,
I am wondering if it's time to replace my petcock?  I have notice a little drip of fluid at the end of the on/res/pri switch lately.  What advice does the COG nation have?  I have included a picture of the petcock.
Starting to get the 1986 ready for COG National in June!!
Thanks
Chris Baum - COG #3088 - 1986 Concours
"A Nebraskan Looking for Twisty Roads!!!!"
2006 Co-COG National Rally Director -
"OTP" Host (2007-09-11-14)     IBA #7474
enim57
Re: Petcock Question
« Reply #1 on: March 09, 2014, 05:17:58 PM »
Yep it's leaking. Replace or rebuild it. Maybe consider a manual option.
Regards, Russell
Offline Summit670
« Reply #2 on: March 09, 2014, 08:17:51 PM »
Chris,
I rebuilt my 87 a number of years ago and it's worked fine ever since.  I've only done one rebuild and have had the bike almost 25 years.
If I had to do it again, I'd think about the converting the stock petcock to a manual, but I'm not sure that would address your leak.
When mine was leaking, I seem to remember it coming out the weep hole on the back of the petcock but I could be wrong.
Jim
Arctic Cat M8 163 rules
Offline Nosmo
« Reply #3 on: March 09, 2014, 10:55:15 PM »
If you rebuild it, be advised that the aftermarket K&L brand kits have had problems in the past with undersized O-rings, etc.  Recommend use only genuine Kawasaki kits.  If you want to go manual, check out  http://www.pingelonline.com  for the best type of manual valve.  Don't faint when you see the price.
Offline Jim __
« Reply #4 on: March 10, 2014, 06:39:31 AM »
If you don't have any visible signs of pitting on the value or seat, I'd rebuild ($13) or I just found a new petcock assembly for $55 (http://www.metricpartsoutlet.com).  When the vacuum diaphragm started leaking on mine from the weep hole in the back, I did a rebuild with Kawa parts and went ahead and did the Bergmen conversion to a manual petcock.  This won't eliminate the possibility of it leaking from the diaphragm but I really like the idea of being able to completely shut the gas off.
enim57
« Reply #5 on: March 10, 2014, 05:53:12 PM »
Murph makes a manual conversion kit that does not use the diaphragm that is a nice job and reasonably priced, see here: http://www.murphskits.com/catalog/product_info.php?products_id=483
I made my own conversion years ago which has even less parts and does not use the diaphragm.
Regards, Russell
Offline Strawboss
« Reply #6 on: March 14, 2014, 06:25:03 PM »
Look at this, it fits my '82KZ550A which has the same part # as my '01 concours, its the same part, matched it up and it looks like it will work, don't see why not.
 http://www.eaglemike.com/Manual-Petcock-for-KLR650-mpcy.htm
« Reply #7 on: March 15, 2014, 04:57:41 PM »
INTERESTING!!
good find, thanks for sharing,
wierd that it says it was manufactured by Yamaha tho ;D
