Author Topic: Danged petcock, hydrolock  (Read 4313 times)
Offline DaveO430
« on: June 07, 2011, 07:16:35 PM »
Got the connie all together and was going to take it down to the station and fll it with gas and ride it to work tomorrow. Put the key in, turned it on and hit the button and no go. I knew immediately what was wrong so I pulled the plugs and cranked the gas out of the cylinders. Put the plugs back in and fired it up and then oil and gas mix came gushing out of the air box. Drained the oil, was a lot in there, at least a gallon of gas with the oil so it got a good flushing out. I checked the petcock and it didn't shut off at all. Took it apart and found corrosion on the seat so I cleaned it up and it seems to work but now I don't trust it.
What would you guys do? Is there a manual alternative?
Offline Badbogie
Re: Danged petcock, hydrolock
« Reply #1 on: June 07, 2011, 08:32:37 PM »
There is a Bergman conversion to manual and also some aftermarket petcocks that will work.  Someone else will chime in, I'm sure.  I have an old Bergman I bought on Ebay that I never used and Murph's carries new  ones.  Really the float valves aren't working right and need to be fixed. Installing overflow tubes in your carb bowls will eliminate the hydrolock problem for good.  PM me if you want my old conversion with a used petcock for the price of postage.
Offline DaveO430
« Reply #2 on: June 08, 2011, 04:16:01 AM »
Bergman, whodathunkit?  I am not pulling those %$#@*&^* carbs off this beast again The needle valves were sealing off fine
when I did have them off, probably a tiny particle of something got in one, actually it was #2.
Offline Centex
    • Central Motorcycle Roadracing Association
« Reply #3 on: June 08, 2011, 09:28:03 AM »
I suspect that you already know all this stuff, but since you asked ...
I like my Pingel manual petcock but I also have SISF's overflow tubes as backup (yep, pull those danged carbs again for that one).
Pingel part numbers, maybe lost in the crash:
Fuel Valve 6211-CH
Adapter Plate A1702C (mates perfect to the Connie bolt holes and tank port - totally OEM appearing solution in chrome, includes all gaskets, bolts and sealer)
You must file the oval tank-port very slightly to clear the 3/8" diameter pick-up and screen.  I did this using out-strokes only and with my shop-vac blowing into the tank-fill to ensure no metal in the tank.  This will NOT prevent re-fitting the OEM vacuum petcock if you want.
Alan in Central Texas
2004 Connie COG 9476
2001 Ducati M750
Offline Mettler1
« Reply #4 on: June 08, 2011, 01:00:34 PM »
  A manual petcock works great IF you REMEMBER to turn it off EVERY TIME!! If you forget even once you could be screwed again.  Overflow tubes are the safety net.
Offline DaveO430
« Reply #5 on: June 08, 2011, 07:06:18 PM »
I remember to turn it off on my 82 goldwing, after I did a total rebuild of the carbs on it and still had it hydrolock once  so I think I could remember on this. I did get the petcock working on the connie to my satisffaction finally. The check valve in the vacuum side was not letting it close. Took a while to figure out what was going on.
Where do I find the particulars on the overflow tubes?
Offline Centex
« Reply #6 on: June 08, 2011, 07:50:43 PM »
....Where do I find the particulars on the overflow tubes?
Click Here
2001 Ducati M750
Offline DaveO430
« Reply #7 on: June 09, 2011, 04:29:24 AM »
Thank's , it's not something you do yourself then.
Offline medicevans
« Reply #8 on: June 09, 2011, 08:03:46 AM »
Oh, I suppose if you had a drill press and a high quality bit you could, but seriously, just send them to Steve.  He uses a press fit and no epoxy or junk to break loose. They will come back to you done right the first time. Are you 100% certain you could get it exactly right?  Cause it has to be. Steve does A LOT of these. You won't be disappointed.
Offline jworth
« Reply #9 on: June 09, 2011, 02:01:26 PM »
A lot of people have done it for themselves.   Depends on how handy you are.
Offline DaveO430
« Reply #10 on: June 09, 2011, 06:20:10 PM »
They just don't come any handier than me. About the only thing I'm dangerous around is paint.
Offline medicevans
« Reply #11 on: June 09, 2011, 06:26:51 PM »
Haha.  Paint can always be fixed, it's just for pretty anyway. Lol  Go for it. Just go slow and you'll be fine.
Offline KenE
« Reply #12 on: June 13, 2011, 11:29:23 AM »
I sourced the tube material, then sourced a drill bit  that allowed a press fit. Practiced in some alu scrap to get it right and tight. I had to get a wee bit smaller bit to allow for my crappy drill press... between lettered, fractional and metric bits a precise fit can be found.
HTH
KenE
