Author Topic: Front tire question  (Read 3196 times)
Offline F-106
Front tire question
« on: June 06, 2011, 04:54:57 PM »
Before I buy i just want to make sure I got this right. If you put a E-3 wing size tire { 13/70/18} it need to be bias to fit the 3" rim. Correct? THANKS
IN THRUST WE TRUST
Offline Daytona_Mike
Re: Front tire question
« Reply #1 on: June 06, 2011, 05:14:19 PM »
13/70/18  ?
Yuk!  Why make a sports car handle like a dump truck is beyond me.  I think you mean 130/70/18.
 Bump.
Offline GF-in-CA
« Reply #2 on: June 06, 2011, 05:19:19 PM »
Correct.  A 130/70 radial is meant to mount to a 3.5" rim, the bias will fit a 3" rim.  Here's Dunlop's fitment info:
E3 bias
http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=86
E3 radial
http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=91
Gary F.
1998 C10
California North State
Offline F-106
« Reply #3 on: June 06, 2011, 07:26:51 PM »
Thanks Gary!
E3 bias
E3 radial
IN THRUST WE TRUST
Offline F-106
« Reply #4 on: June 06, 2011, 08:34:29 PM »
The sports car as you call it only sees the freeway. The only turns I go through are on off ramps.
 Bump.
IN THRUST WE TRUST
Offline Mettler1
« Reply #5 on: June 06, 2011, 08:58:36 PM »
    No curves??!! That's really too bad. :(
