Author Topic: Juice Box Pro installed  (Read 2567 times)
Offline Deathwish
« on: June 04, 2011, 03:40:17 PM »
Was debating on getting the DynoJet PC V or the Juice Box. Found the Juice Box Pro for about $250 brand new, so decided to go that route. Just got it installed today (after removing my flies) and I couldn't be happier. The JB Pro can hold up to 10 different fuel maps and you can change maps "on the fly" with a small phillips head screwdriver. The unit came with a zero map, a stock exhaust map and a map for the Two Brothers slip-on. I was able to locate (with the help of a board member)a DynoJet map for Two Brothers slip-on/flies out and imported it in to the Juice Box with no issues. Just got back from a test ride and all I can say is WOW!!!!! I had an ATRE on the bike before, but removed it when I pulled the flies. The ATRE does not compare with actual fly removal and the right map. I'm a happy camper  ;D ;D
Offline tyler1015
Re: Juice Box Pro installed
« Reply #1 on: June 04, 2011, 06:04:37 PM »
Sounds awesome. Glad it was able to help u smile with your sick. I was shocked when I did the same setup as u. The bike finally felt like the zx14 roots it has.
Offline Deathwish
« Reply #2 on: June 04, 2011, 07:04:17 PM »
Thanks again Tyler!  8)
