Author Topic: Fan Switch cross-ref #?  (Read 8315 times)
Offline Summit670
« on: June 04, 2011, 08:38:36 AM »
My fan switch is bad and I know there is an automotive X that is like half the price.
Anyone know the X-ref numbers?
I beleive the OEM # is 27010-1202 and is around $50.
Thanks.
Arctic Cat M8 163 rules
Offline Summit670
Re: Fan Switch cross-ref #?
« Reply #1 on: June 04, 2011, 08:46:29 AM »
Found this doing a google search.  I guess it is on here somewhere.  Is it accurate and is there a closer (higher) automotive temp range?
Switch Cooling Fan Kaw p/n 27010 - 1202(ZG10/ZX11)
ZRX is 27010 - 1372 ??($40), all switches listed bellow
will have a lower temp range than stock.
Turns fan on at 191-197F (ascending) and off at 182-
187F (descending). Take your old one to check for fit
and connector.
ACDelco: E-1858
Auto Tune: PT2628
Beck/Arnley WorldParts: 201-0817
Beck/Arnley WorldParts: 201-1369
Borg Warner: TFS500 (Tom Masterson)
Echlin (NAPA): FS-130
Facet: FS8404 (Chris Roy)
Filko: TFS-1 (Bob Chappell)
Four Seasons: 35934 (Bob Chappell)
G.P. (?): 40-5001
Kem: TW-65
Mitech: TS-84
Niehoff TS 82001
Motorcraft: no interchange
Niehoff: WA-639B
Standard: TS-84
Wells: SW504 (Guy B. Young II)
« Reply #2 on: June 04, 2011, 08:47:19 AM »
Borg Warner: TFS500
Facet: FS8404
Filko: TFS-1
Four Seasons: 35934
Wells: SW504
Offline Summit670
« Reply #3 on: June 04, 2011, 09:47:19 AM »
Thanks.
Autozone carries the Wells and it is $23 plus tax.  They will get one in 4 hours.
Napa was $49 and in stock.
Oreilly carries Borg W $23 and a few days to order
Car Quest carries Wells and was $20 economy or $40 premium, a few days order
Advance carries Borg W $29, a few days order
« Reply #4 on: June 04, 2011, 02:14:57 PM »
hehehehehe
roll over tothe junkyard and pull one off a late 70's toyota corolla.....bring the wrench, i'll bet you can get it for a buck..... ;D
Offline Summit670
« Reply #5 on: June 04, 2011, 06:44:34 PM »
The Autozone unit is about 1/8 to 1/16 longer from the o-ring to the end.  Screwed it in by hand until the o-ring seated and tightened up with a wrench, carefully.  Seems to fit ok.
Are all the aftermarket units a little longer?
Offline RapidRoy
« Reply #6 on: June 05, 2011, 10:31:07 AM »
This site rocks! Or should I say, the posters on this site Rock! Where else can you go ask for alternative replacement options for an esoteric part and get information like this.
I think I'll be able to keep my Connie going forever with this kind of information. Thanks guys.
'99 C-10
Offline Summit670
« Reply #7 on: June 05, 2011, 04:34:13 PM »
BTW - I believe I like the lower kick on temps for fan.  I was worried it may run too long when the bike is shut off, and maybe it does, but the fan run time diff is not noticeable.
Find out how it works for sure tomorrow.  The temp is supposed to be around 98 here.
