Author Topic: clutch  (Read 4641 times)
Offline tracyscoleman
clutch
« on: June 01, 2011, 06:23:07 PM »
how do i remove star spring nut 36mm
Offline RFH87_Connie
Re: clutch
« Reply #1 on: June 01, 2011, 06:32:34 PM »
A big socket wrench and pet gorilla.
Offline syntor
Re: clutch
« Reply #2 on: June 01, 2011, 06:37:07 PM »
Big socket and a rattle gun.
No gorillas here.  :P
Re: clutch
« Reply #3 on: June 01, 2011, 06:48:40 PM »
Appropriate six point socket and a long breaker bar.  I had an assistant sit on it and hold the rear brake while in gear.  Not the best way but it worked fine.  If you KEEP the bike on the side stand you don't have to drain the oil while you do the job.  Account for all the pieces before you close it up.  I used Yamabond with no gasket on the cover.  There is a thread going on discussing a tool you can make or buy on the forum right now.
Offline Daytona_Mike
Re: clutch
« Reply #4 on: June 01, 2011, 07:44:42 PM »
Yup. That is how I do it. Off and on.
Re: clutch
« Reply #5 on: June 01, 2011, 08:14:56 PM »
no gorrilas here  ;) bigggg socket yes long breaker bar yes how do you stop inner housing from turning ? :( outer cover with 6 bolts and springs must be removed to get to nut  ??? how do you stop inner basket from turning :P????  ps how do i get to that thread on tool  pss one of the fingers on spring is broken off or i would leave it alone
Re: clutch
« Reply #6 on: June 01, 2011, 08:19:16 PM »
i'm not much of a wrench head whats a rattel gun? an impact gun :o
Offline Summit670
Re: clutch
« Reply #7 on: June 01, 2011, 08:32:36 PM »
I will make a tool next time, if needed.  When I did it I used an impact wrench, testing the diff gun settings on my truck lug nuts and seeing what the torque wrench said the torque was (approx for sure).
Then I used the closest setting to tighten the clutch nut.
You may find a socket to borrow at the auto parts store.
You may also cross ref it to an SAE size because it may be close enough. I believe 1 1/16 is the size I used but not 100% sure.
Harbor freight has some very large wrenches, metric, for about $40.  Not sure if the size you need is in the kit.  I just took my kit back because the wrenches were too wide for my ATV application.
Arctic Cat M8 163 rules
Re: clutch
« Reply #8 on: June 02, 2011, 10:38:11 AM »
I believe I used a 1-3/8", as it seemed to fit a bit tighter onthat tiny nut section, also try to find one without a huge chamfered "mouth", I took the one I had and ground the face of it back about 1/8" to remove most of the chamfer. it provides a much more reliable fit.
Re: clutch
« Reply #9 on: June 02, 2011, 10:43:46 AM »
i cant seem to be able to stop inner housing from turning while trying to loosen nut
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
Re: clutch
« Reply #10 on: June 02, 2011, 11:38:54 AM »
Re: clutch
« Reply #11 on: June 02, 2011, 02:46:37 PM »
i've tryed nylon straps wrapped around the gear back to the footpeg man is that nut tight :-X!!! still won't break lose     the picture on that they used a bicycle brake cable screwed to a clutch plate i don't think thats strong enough i had a simular idea though my idea needs welding
Re: clutch
« Reply #12 on: June 02, 2011, 06:05:00 PM »
 :D!!! yaaa  thanks guys i got it 98ft. lbs a screw and a bicycle cable and an gorilla named dave he may be for hire ;D on to the ape timing chain tensioner 8)
