Author Topic: Just bought a 2002 Connie and have a stupid question  (Read 7032 times)
Offline extrapc
« on: May 31, 2011, 07:22:13 PM »
OK, I used to have a Honda Shadow and now have a Connie.  I guess my big question is where should I be riding RPM-wise?  I was used to my old bike and shift what seems early on the Connie, as I seem to run out of gears.  If I wait until 4,000 RPM, I seem to flow fine into clicking into 6th about 55-60, otherwise if I shift as I used to on my old bike, about 45 I am out of gears.
Do I just need to learn to shift at 4,000?
I never come close to red lining the bike, should I be holding off shifting even longer?
Just wanting to know where I should be shifting.
Thanks!
Offline roger dodger
  • Keep it between the ditches
Re: Just bought a 2002 Connie and have a stupid question
« Reply #1 on: May 31, 2011, 07:26:23 PM »
Shift @ 4k = mild
Shift @ 6k =  fun
Shift @ 8k = wild
JMHO  ;)
'03 FJR
'02 C10 (mia)
'81 KZ1000
Offline GF-in-CA
« Reply #2 on: May 31, 2011, 07:32:00 PM »
Shift @ 4k = mild
Shift @ 6k =  fun
Shift @ 8k = wild
JMHO  ;)
+1, with the adder that the oil pressure on the C10 starts dropping off under 3k, so in anything above 1st gear, it is best to not let the revs drop below that number, at least not with a large throttle opening.  Have fun!
Gary F.
1998 C10
California North State
Offline medicevans
« Reply #3 on: May 31, 2011, 08:03:32 PM »
Shift @ 4k = mild
Shift @ 6k =  fun
Shift @ 8k = wild
+ 2 on both the above posts.  I came from an 1100 Shadow ACE T and let me tell you, going from a v-twin to an I-4 is a big big change.  Learn to love the revs, because your engine does.  The Conc isn't a twin.  Let it wring out a little bit.  I tell you, I spend a good deal of time now north of 5000-6000 RPM.  It's like going from a pickup truck to an Indy car.  Let the thing run.  As stated, keep the revs above 3k so there is good oil pressure.  I have a manual Chevy Blazer that I shift at 1400 to conserve fuel.  DON'T DO THAT WITH THIS BIKE.  Rev it up a let it sing.  Shift at 4k every time.  Maybe once or twice let it head up to 9k+ and shift high and fast just to see what it feels like.
Offline Cholla
« Reply #4 on: May 31, 2011, 09:13:51 PM »
And lugging the engine is hard on the u-joint.
BTW-just because an engine is a v twin doesn't mean they don't like to rev and all the toorque is down low. Know your engine's characteristiscs.
The OP asks a good question!
Offline nosaint7
« Reply #5 on: May 31, 2011, 09:29:59 PM »
Shift @ 4k = mild
Shift @ 6k =  fun
Shift @ 8k = wild
JMHO  ;)
+2 - Yup - I moved from a Yamaha V-Star to a 2003 Connie about 6 weeks ago.  Have been moving my shift points up a little higher in the revs every week.  Now run to 8k on occasion (when there is enough open space! :thumbs:).  4k minimum took a bit to get used to as the Star had a 6k redline...
current: 2003 C10
past: Yamaha Vstar, Yamaha XS750, Suzuki T500, BSA 650 Lightning (yup - I'm OLD!)
Offline DarkKnight
« Reply #6 on: June 01, 2011, 05:29:36 PM »
u joint? my joint or your joint? what joint we talking about?
Offline qman
    • Autobahn Motors
« Reply #7 on: June 01, 2011, 09:08:51 PM »
wouldn't it be "who's joint are we talking about"?
ewe r just such a funny guy! :rotflmao:
Offline Lodogg2221
« Reply #8 on: June 01, 2011, 09:19:27 PM »
I had the opposite problem with my VTX.  Ran too high before shifting and ran smack into the rev limiter...but man that thing would haul in 1st and 2nd...
Ive only hit the limiter once on the Connie...not quite used to it yet.  Still having visions of my old Z1000, with its higher limiter I guess.
Say what?
Offline gtr1000
« Reply #9 on: June 02, 2011, 01:58:37 AM »
On a C-10? I thought they revved until the valves bounced  ;D
Paul OTP (near Windsor, GB).
06 C-10, 2009 to .....
A5 C-10, 2000 to 2009.
Offline Daytona_Mike
« Reply #10 on: June 02, 2011, 06:03:04 AM »
Yup, at 9k the power drops off so it would be better to shift no higher than ~9k.  On the low end , I can tool around at 2 to 2.5k but that is with custom cams and 2 minute mod (1052 kit, 4 into one exhaust  and  on and on). Pure stock Connies loose much of their grunt below 4k.
« Reply #11 on: June 02, 2011, 06:32:39 AM »
Correct the ZG1000 has no built in electronic rev limiter.....
Offline Lodogg2221
« Reply #12 on: June 02, 2011, 08:45:44 AM »
Ok, well I hit the point where it stops reving...its very distinct.  Not sure one way or the other, but it sure felt like a limiter....but I suppose lack of all power is about the same thing.
Anyway, its around 9.5K or so.
Say what?
Offline ManWorkinghere
    • Avatar database
« Reply #13 on: June 10, 2011, 09:21:31 AM »
I just had the exhaust valves replaced during a recent valve job and now the bike idles real smooth down around 1200-1500.  New to this feeling after owning a 2001 Connie for just a second year.  What is the downside of running at lower revs?  I am riding around 3700-4000 maybe at 65-70 on the freeway for most of my driving.
I will have to try high revving and shifting in some safe place to see what that feels like sometime.
Offline nosaint7
« Reply #14 on: June 10, 2011, 10:35:27 AM »
Constant 3700-4000 revs on freeway - no problem with oil pressure (see above).  If you want/need RAPID accel, then you may want to downshift one or two gears.  For me, one gear down for extra "oomph" is usually enough on the freeway.
current: 2003 C10
voileauciel
« Reply #15 on: June 23, 2011, 09:22:00 AM »
I came close to this on the third day I had this bike. Went to downshift to merge onto a highway and accidentally went into 1st! Tach went straight to 10.5k and made a BOING sound. I had snapped the clutch back in so it didn't pass the redline, but whew that scared the heck outta me!
Done 32k since, no issues, and I've been very careful about downshifting ever since!
Offline txfatboy
« Reply #16 on: June 24, 2011, 12:11:24 AM »
Keep in mind, all these replys refer to a "stock" Concours. Talk to SISF (Steve)  and its a whole different story.......  ;D
Oh, yeah, Rev or Jim B. might be able to help as well......
Woody
2014 V-Max
1991 Connie, 17 inch wheels,  ZRX1200 forks with racetech valves and brakes, zx9/ zzr1200 hybrid rear shock, 2 min mod and exhaust cam sprocket from SISF, tubular handle bars, hywy pegs, HID headlight and LED running lights.
Offline medicevans
« Reply #17 on: June 24, 2011, 05:23:03 AM »
At least the Conc has a factory slipper clutch! That could have been bad!
voileauciel
« Reply #18 on: June 24, 2011, 05:27:28 PM »
Yes indeed! Every time I ride a bike that doesn't have one, I take extra precaution when downshifting.
Should be fun once I buy the KLR, going from the Connie to that and back again, haha!
