Author Topic: Oil leak, now with coolant  (Read 2514 times)
Offline dboogie2288
    • Beginnerbikers.org
« on: May 31, 2011, 03:59:35 PM »
First off, WOAH!
COG/ZGGTR has changed so much over the past year or so and what a mess! Anyhow, glad I found my way back here. I had searched here and there and I think its the water pump seal that is going bad. My 86 connie with 60k started with an oil leak early in the year. I had pulled the plastic off to try and diagnose, with no luck as of yet. Just recently after moving to remove the plastic, I saw coolant in the oil leak. I think it's that water pump seal that I've seen threads on...
Can anyone confirm this, and if so point me in the right direction to correct? Thanks,
Offline Mettler1
Re: Oil leak, now with coolant
« Reply #1 on: May 31, 2011, 04:37:25 PM »
    The water pump has an O-ring seal to keep the oil from leaking out of the engine case. The O-ring is replacable if is the cause of the oil leak.  Look at the bottom of the water pump. You should see a small weep hole. If you see antifreeze leaking out of the hole you probably need a new pump. It is not rebuildable. Murph's has them.
  http://www.murphskits.com/catalog/product_info.php?cPath=1_93&products_id=149
Offline Summit670
« Reply #2 on: May 31, 2011, 07:11:39 PM »
If your coolant is coming out of the weep hole you need a new pump.
If oil is coming from the weep hole you need a new oil seal but you might as well do the pump replace because you may need it soon anyhow and a new seal is tough to get seated so it stays put.  A thought on the seal - if it is leaking oil that oil must be going thru the bearing.  If the oil washed out the bearing grease then the bearing life may be limited with a new seal?
I've done the oil seal twice or thrice, finally enlarging it a little with a socket pressed in a little to widen the O.D. of the seal.  Some say loctite red does a good job holding it.
If oil is coming from the o-ring area and not the pump you can replace the o-ring.  You will want to replace the water pipe o-ring in the process.
Arctic Cat M8 163 rules
