Author Topic: spark plug thread size??  (Read 3468 times)
Offline Noho Drewster
« on: May 31, 2011, 06:03:17 AM »
Bought a $20 compression tester from Harbor Freight and the 12 mm adapter almost stripped out #4 plug.  Anyone know what the tread size is, or where I can find an adapter??
Thanks, Drew
'94 C-10
'79 Shovelhead
Re: spark plug thread size??
« Reply #1 on: May 31, 2011, 07:04:23 AM »
14 mm thread and the pitch I think is 1.25 pitch.
« Reply #2 on: May 31, 2011, 03:03:34 PM »
OK, Thanks Tony!!
'94 C-10
'79 Shovelhead
« Reply #3 on: June 15, 2011, 04:04:36 PM »
Just an FYI Tony,
the plugs are 12mm.
Drew
'94 C-10
'79 Shovelhead
Offline Mettler1
« Reply #4 on: June 15, 2011, 05:13:22 PM »
Just an FYI Tony,
the plugs are 12mm.
Drew
  Funny. I thought so too but I would NEVER question Tony. He knows everything!!! :yikes: ;D ;D
« Reply #5 on: June 16, 2011, 05:42:02 AM »
NOPE .... I make mistakes too.... Funny thing is I double checked across a chart and I'm fairly sure the chart is correct so I can only blame my old eyes and being eager to post an answer. Must have crossed my B's & D's
« Last Edit: June 16, 2011, 06:31:53 AM by T Cro ® »
Offline Dan
« Reply #6 on: June 17, 2011, 10:41:56 AM »
Do u guys run ngks?
Since I am trying my first valve adjustment, figure I will put in new plugs as well....
Dan
Offline gtr1000
« Reply #7 on: June 17, 2011, 12:09:24 PM »
Do u guys run ngks?
Dan
Yep, Iridiums at the moment and before that, standard NGKs. Never rated Champion or Nippon Denso but have occasionally used Bosch.
Paul OTP (near Windsor, GB).
06 C-10, 2009 to .....
A5 C-10, 2000 to 2009.
Offline Jet86
  • California
« Reply #8 on: June 17, 2011, 02:50:45 PM »
Over the last few months my bike was getting harder to start and once it was running and going down the road it was good but if i turned it off to run in the store and come out 15min later it did not want to start until a big backfire out the right tailpipe, i thought it was my carb's cause i know they need cleaning but after adjusting my valves and putting in a new set of NGK D8EA this girl woke up, she now starts Immediately, there was only 2 valves outta spec so i don't think that was causing the backfire, now i know what to do when she gets hard to start or backfires.
