Author Topic: Horsepower differences in model years?  (Read 5184 times)
Offline DaveO430
« on: May 28, 2011, 05:46:41 PM »
Noticed in the manual the early model C10s were rated at 110PS (approx 108 HP) and the 90> models rated 92 PS (90 HP) what is the difference in the engines and is there a real world difference?
Offline Mettler1
Re: Horsepower differences in model years?
« Reply #1 on: May 28, 2011, 06:08:25 PM »
  The red Concours has the most HP and therefore is the fastest!!
Offline Mettler1
« Reply #2 on: May 28, 2011, 06:14:23 PM »
  I'm guessing but the highest HP was measured at the crank and the lower number at the rear wheel? AS far as I know KAWASAKI never did anything to the engine to increase HP in the C10.
Offline DaveO430
« Reply #3 on: May 28, 2011, 06:29:10 PM »
Looking at the book some more and the 2000 suplement goes back to the 110 PS. the 110PS rating is at 9500 RPM where the 92PS rating is at 9000 but the torque figures are also different, much lower torque figures on the 90-99 models, at the same RPM. Must be where the measurements were taken, crank or rear wheel, they just don't desgnate that.
Offline GeeBeav
« Reply #4 on: May 28, 2011, 06:37:42 PM »
Are you sure you are looking at all US models? The engines were tuned differently for different markets.
Offline Mettler1
« Reply #5 on: May 28, 2011, 06:40:00 PM »
 Or the government made them use honest HP!
Offline Mettler1
« Reply #6 on: May 28, 2011, 06:47:41 PM »
  This is interesting.
http://neptune.spacebears.com/opine/horsepwr.html
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #7 on: May 28, 2011, 07:17:18 PM »
the us modes were the same across the board, but the euro models had some with lower hp, mostly due to restrictive caps on the carbs. the euro guys buy the us diaphram caps to boost thier hp.
   Also at the dyno day we had back in february, I saw a stock connie at 84 hp, and another at 97 hp. I've seen several 84 hp bikes, but never a stocker at 97. I'd say the average bike is in the 88 - 89 area. Steve
« Reply #8 on: May 28, 2011, 07:29:47 PM »
  Here's a chart of a stock connie, mine, and a c-14 on the same day. Steve
Offline syntor
« Reply #9 on: May 28, 2011, 07:55:43 PM »
Also we got the pea-shooter mufflers, with a 5/8" diameter hole to restrict the exhaust flow, Yankee mufflers with a baffelectomy are much better!  :)
Offline DaveO430
« Reply #10 on: May 28, 2011, 08:48:04 PM »
The manual I downloaded from this forum has all the different numbers for the different markets except some of them do not list US Hp . (or I didn't see it) so I used the PS #s as examples.
