Author Topic: This forum is dead dead dead  (Read 6802 times)
Offline Uded2me
« on: May 12, 2011, 08:00:07 AM »
d e a d
« Last Edit: February 21, 2016, 09:01:44 PM by knight_mare »
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
Some J-Box problems can prevent starting. Next time it doesn't start, just bash the J-Box a bit, see if that does it. Fiddling with the fuses may have accomplished the same thing.
There may be dodgy solder connections or relays that need to be replaced.
Offline Uded2me
« Reply #2 on: May 12, 2011, 08:24:17 AM »
d e a d
« Last Edit: February 21, 2016, 09:01:51 PM by knight_mare »
Offline Cholla
Clean the fuse contacts.
Offline Mettler1
 Dirty contacts in the starter button?
Offline Nosmo
Also, check the tension of the contact tabs in the fuse holders.  I had one of the fuse holder tabs (contacts) get loose and it melted my J-box.  When I repaired it, I squeezed them all so they would grip the fuse tabs and the soldered tabs on the circuit board real tight.  I'll try to attach a pic of the damage.
pic below (I hope):
Offline Uded2me
« Reply #6 on: May 13, 2011, 12:44:36 PM »
d e a d
« Last Edit: February 21, 2016, 09:02:55 PM by knight_mare »
Offline KenE
Same problem for me was loose battery cable bolts... Simple, but it made me crazy, being so intermittent in nature.
hth
Offline Uded2me
« Reply #8 on: May 14, 2011, 06:32:17 PM »
d e a d
« Last Edit: February 21, 2016, 09:03:21 PM by knight_mare »
  • Moderator
