Author Topic: A or B Key, how do you figure that out?  (Read 19051 times)
Offline HndaTch627
« on: July 26, 2012, 04:59:48 PM »
If it's the first letter of the Key code then I've got my answer. I need to order 2 passive fobs as it seems as though my ex-wife lost my other active fob.  I want to order 2 of the passive fobs and 2 keys but need to figure out which keys to order.
Thanks for the help guys!
Jeremy
Re: A or B Key, how do you figure that out?
« Reply #1 on: July 27, 2012, 04:35:04 AM »
Try looking here....a little bit more than halfway down.
http://www.zggtr.org/index.php?topic=1650.0
« Reply #2 on: August 31, 2018, 02:58:15 PM »
or here...
recently updated to show FOB key blanks
http://www.zggtr.org/index.php?topic=1650.msg295905#msg295905
« Reply #3 on: October 01, 2018, 06:36:24 PM »
NEW info for passive fob replacements...
especially for those with "left hand" keys...
HERE ARE ALL THE KEY BLANKS
27008   27008-0048   KEY-LOCK,BLANK,#A
27008A   27008-0049   KEY-LOCK,BLANK,#B
27008B   27008-0050   KEY-LOCK,BLANK,#A,MAIN SWITCH
27008C   27008-0051   KEY-LOCK,BLANK,#B,MAIN SWITCH
27008D   27008-0062   KEY-LOCK,BLANK,#A,SPARE FOB
27008E   27008-0063   KEY-LOCK,BLANK,#B,SPARE FOB
RECENT discovery...
a key with capability for containing a 'clonable chip' is available for use with a JMA-TPX2 chip, which requires the locksmith to have a JMA TRS 5000 Evo electronic chip programmer, but it is out there...
appears to be a JMA key...
https://www.ebay.com/itm/JMA-transponder-key-shell-Yamaha-YAMA-26D-P2-/281687254794
https://www.lockpicks.com/yamaha-motorcycle-chipless.html
https://americankeysupply.com/product/yamaha-cycle-transponder-key-shell-ym63-style-jma-yama-26d-p2
https://www.autotechlocksmith.com/41-motorcycles/2615-yamaha-transponder-key-shell-ym63-tp00yama-26dp2.html
that is the "key SHELL", without a chip, it will accept a JMA TPX2 chip, which is available all over...
unfortunatly it, as I am seeing, is only the 'left hand key', I'll look for a right hand key version shortly...
but if your key matches the following ones, shown pictorially, it's covered.
the key will not fit in the fob, but it can be cut as a normal spare, and a chip can be inserted and cloned...
note: because this is a 'cloned chip', you must have a fob to use as a master, but it copies the OEM code on said fob chip, and thus DOES NOT require using the KDS3 to reprogram the ECU.. major savings.
EDIT;
for the right handed keys, these are the ones you need....
(the ones correlating to the "#B Blank Kaw locksets"
Blade:Standard Ilco:KW16MH
JMA #:TP00KAW-9.P1
Chip:No Transponder
Notes:Transponder Key Shell
http://www.keynet.com/jma-kawasaki-transponder-key-shell-kw16-style-tp00kaw-9-p1/
« Last Edit: October 28, 2018, 03:08:26 PM by MAN OF BLUES »
« Reply #4 on: October 03, 2018, 01:53:34 PM »
Thanks, Rich.
