Author Topic: ECU reflash vs PCV?? - NEED YOUR HELP PLEASE  (Read 8372 times)
« on: July 23, 2012, 08:35:49 PM »
Hey you guys with KTRAC, what are the advantages/disadvantages of reflashing the ECU vs doing a PCV??  ??? :-\
Gumbi just bought a full system for his 2011, we were talking tonight and I'm trying to help flush out the difference... ??
I have a PCV, but I also have an 09 which doesn't have KTRAC, so I just did the PCV and pulled the flies... But it's a little different for Gumbi's 11 model with KTRAC...
Please help, thanks!  :chugbeer:
Offline C1xRider
Re: ECU reflash vs PCV?? - NEED YOUR HELP PLEASE
« Reply #1 on: July 23, 2012, 08:49:10 PM »
I've given this a lot of thought, and here's where I'm at.
If I were to go with the PCV, then I'll want the auto-tune add on w/ the O2 sensor.  I don't like relying on other to create maps for me, or the trial and error process of getting them right.  A closed loop system is the only way to go.  Pulling the flies would adversely affect KTRC.
If I were to do a reflash, I want the tools and the code (map info) to do it myself.  Again, I don't like relying on others to "get it right".  Plus, I would want to do some other tweaking in the code for sure.  Even with this, I would probably add a O2 sensor just for feedback.
So, given my criteria, PCV is the only option at the moment.  However, there are plenty of folks that have reflashed their ECUs and claim to be happy.
Do they even have a reflash option for the 2011 w/ a Muzzy dual, and a air filter?
Offline Cuda
« Reply #2 on: July 23, 2012, 09:03:00 PM »
I ride on wet roads A LOT  and  I love the way it stops the spin . One of the reasons I bought the Connie.
Lets face it this bike has LOTS of power stock and unless your drag racing at the track and need that extra .10 of a second  I  believe in keeping it SIMPLE  . I also like to ride in ECO mode  (cheap A$$)  ;D
Gods waiting room Naples
2011 Atomic  Silver
« Reply #3 on: July 23, 2012, 09:36:38 PM »
Well, it's past 8:30 now Cuda, so I'm already 10 beers into the night brutha, can you be more specific??  ???
So are you saying ECU reflash or PCV??
I believe both options will still keep his KTRAC functioning as designed right?  :-\
« Reply #4 on: July 23, 2012, 10:27:37 PM »
On my other thread you put:
I put a ZX header with out CATs  dual 2 Brothers and it was FINE don't waste your money like ZG :o
You will NEED ear plugs though .
Are you saying you did not do anything above and beyond adding dual exhaust? If so, do you have any backfiring on decel? And did it change your gas mileage much?
I don't mind ear plugs. That is almost one of the reasons I bought these cause my AreaP started quieting down after about 1,200 miles. Odd huh?
« Reply #5 on: July 23, 2012, 10:29:38 PM »
Pick up the pace....... 8)
« Reply #6 on: July 23, 2012, 10:45:31 PM »
Sorry, I don't have 3 kegerators like you... CC&R's are a little different on Bull Mountain vs North Plains...  ;)   :chugbeer:
« Reply #7 on: July 24, 2012, 03:49:59 AM »
Ideally with traction control, which does use the secondaries, I would spend your money to have Guhl Motors reflash the ECU to open the flies sooner. I would also install a PC5 w/autotune to trim the baseline map installed at the reflash. I would then schedule some dyno time to tweak it to perfection. This is probably overkill and somewhat pricey but keep in mind I'm spending your money. :)
Offline Cuda
« Reply #8 on: July 24, 2012, 04:35:31 AM »
It's been 15 years since I've had 10 beers in one day. ;) lots of water and diet coke.
I like the Guhl reflash , it keeps the eco mode and keeps  the secondary flys for better traction control, smooooooth .
Yes I first put the pipes on with no reflash and had NO problems, you must close that hose in the air box to help with the poping sound on downshifting, though I kind of liked it :)
No hesatation what so ever.
2011 Atomic  Silver
Offline cablebandit
« Reply #9 on: July 24, 2012, 06:41:26 AM »
No flies and PC5 works fine with traction control.  The only way you really know Ktrac kicked in is seeing the light flashing.
« Reply #10 on: July 24, 2012, 09:11:53 AM »
I'm with you, its hard for me to trust a canned map or reflash in comparison to a 02 sensor and PC-V adjusting in real time
« Reply #11 on: July 24, 2012, 01:35:53 PM »
 :o    Interesting, it's been 15 years since I haven't...  ;)
« Reply #12 on: July 24, 2012, 02:57:12 PM »
I believe we discussed this at length in another thread a while ago.  The traction control *does* use the secondary butterflies, but only as part of the strategy.  So if you disable the flies, it should theoretically make the traction control less effective, but it doesn't totally ruin it (according to what I remember from other posts).
The light will flash when it has sensed a loss of traction and is trying to correct the problem.  But that doesn't mean it *can* correct it well if something it relies on is disabled.  Even if it has zero control to correct the slip, it will eventually be corrected and the light go out; and that usually all happens pretty quickly.
Offline cablebandit
« Reply #13 on: July 24, 2012, 03:34:13 PM »
And yet it does.
Offline Cuda
« Reply #14 on: July 25, 2012, 04:43:07 AM »
So Steve this is what you did on your bike?
2011 Atomic  Silver
Offline Fretka
« Reply #15 on: July 25, 2012, 01:57:11 PM »
My beast does not have TC but if I can make an educated guess, the strategy TC uses to maintain traction PROBABLY is:
First action: retard timing (fast and effective to a greater degree).
Second action: lean out intake charge (both might be used in conjunction).
Third action: close flies (last resort and only used when above does not produce required parameters).
The first 2 actions are more seamless.
This last takes somewhat longer time to enact and produces a large "felt" response. Hence its use as a last ditch command.
This explains why loss of fly manipulation still results in an effective TC response.
Offline KaTieM505
« Reply #16 on: December 11, 2012, 02:49:26 PM »
Okay,
I am sitting on a full Area P exhaust, PCv and BMC filter. I do not want to sacrifice the Traction Control.
After those of you that have removed the flies and installed the Power Commander and most importantly, put a few miles on your bike, what is your oval experience with this setup.
Thank you for your time to respond.
Randy
