Author Topic: Lowering the 1400 Concours  (Read 20611 times)
Offline Clark Kent
« on: June 29, 2012, 02:05:51 PM »
I am short 5'7" now and have to get use to it.  I was 5'8" when I was younger.
I can't Flat Foot the 1400 and won't ride one I can't FF.
How do you get a 1400 Concours down to my level?  I see that the standard seat height is 31.5"
How low canit go?  I would need at least 2"
Right now I have an st1100 and am just shy of being able to ff it.  I have a Valk and an 1800 GW.  I can FF both of them easy.  That's what I'm looking for in the 1400.
Thanks,  ck
(I can see all kinds of openings for jokes here but I really just need to find out how to get the bike lower.)
  Visit me in the Arena and bring all those jokes.   :chugbeer:
A gun is as good or as bad as the man using it.  "SHANE"
Offline blue14
Re: Lowering the 1400 Concours
« Reply #1 on: June 29, 2012, 02:36:22 PM »
2010 C14, 2007 ZX14,  2004 KTM 300SXC
« Reply #2 on: June 29, 2012, 03:16:52 PM »
Not sure lowering this bike would be smart, and why must you totally be able to flatfoot?
Offline SoberFX
  • 2008 Concours 14 It's All Good!
« Reply #3 on: June 29, 2012, 03:52:07 PM »
I had a hard time with the stock seat and doing the tip toe deal.  Got the Corbin seat and now can flat foot my right foot while left is on brake.  Just sayin'
FX
« Reply #4 on: June 29, 2012, 04:02:21 PM »
These guys said you could borrow a set of their boots.
IIRC maxtog is short also and had to use a combination of lowering links and a shorter seat to reach the ground.  You might send him a PM to see what worked well.  I would try to keep from lowering the bike to much if at all possible but you gotta do, what you gotta do.
« Reply #5 on: June 29, 2012, 04:43:38 PM »
I am short 5'7" now and have to get use to it.   I can't Flat Foot the 1400 and won't ride one I can't FF.   How do you get a 1400 Concours down to my level?  I see that the standard seat height is 31.5"
Welcome, "Clark"!!!!  I can very much relate to your situation.
Always search first (on both accessories and "the bike" forums).  Here is the thread you need:
http://www.zggtr.org/index.php?topic=260.0
I have pasted your questions there and replied to them there...  (I have no idea why this board puts a stupid warning on posting to old threads.  It is FAR better to continue a discussion in one place than to have it in many)
« Last Edit: June 30, 2012, 07:26:31 AM by maxtog »
Offline Clark Kent
« Reply #6 on: June 29, 2012, 09:22:31 PM »
Thanks to all.  I will try to address each question:
Blue 14:   Isn't 4" too much?  Wouldn't the pan be to close to the ground?
 Jeremy Mitchel:  I could sure use the boots but how would I get all that hair inside my helmet?
Pokey:  I am just too old to hold up that much weight without the feet being flat. If i'm not 2 up I can do it.
It may be just too much expense and trouble.  My wife says I should get high heel boots!  (Very funny)
Then she has the gall to get upset that I make her walk home!   :rotflmao:
To safely ride the 1400C what inseam should someone have?  Flat footing or not.
I have an inseam of 31-3/4 with bare feet on the floor
« Reply #7 on: June 29, 2012, 09:50:37 PM »
I'm a 29 inseam CK, I got a Corbin seat with nose job and deep dish cut which dropped it almost 2" from stock seat height, now I'm good to go.
I also agree with Poke, there is no reason to need to completely flat foot this bike, the balls of your feet work just fine...
Good luck bro!  :chugbeer:
Offline Lone-Rider
« Reply #8 on: June 29, 2012, 10:26:06 PM »
I am 5'8" on a good day with a 28" inseam. I spent 9 years on a C-10 and learned that if you use your skull muscle you can get around it. I don't try to "pad" the bike backwards, I am picky about where I park, if I have to back out I walk the bike out before getting on it. At stops, I could easily FF on one side with a little lean, and found it to be very stable.
I got my C-14 yesterday, and those things work just as well. I think the C-14 might be just a touch taller than the C-10 and I plan on getting a Sargent low seat which will help even more. I thought about lowering bikes in the past but when you do you screw with the geometry and then have to deal with modifying or swapping the side stand and usually give up the center stand unless you know someone who can do a cut and weld job.
Offline lt1
  • 2008 C14
« Reply #9 on: June 29, 2012, 10:43:40 PM »
If you really "won't ride a bike you can't flat foot", then I think you ought to pass on the C14.
As to my personal experience, I normally wear 32" inseam pants.  Out of curiosity, I measure pants crotch to floor and came up w/ 31.25".  I normally cannot flat-foot the bike w/o wiggling around on the front part of the seat, but it is easy to get the balls of both feet firmly on the ground, with the boot heels just hovering off the pavement.
Backing up is not particularly easy, but only becomes an issue if I'm trying to back uphill (even on slight grades).  I have learned to be careful where I park.  Sideways inclines can be a stopping/parking risk as well - I dropped the bike once on a slant on a cold, rainy day.
A lowered/shaved seat may help.  Lowering the suspension is possible, but has side effects, which may or may not be of concern to you.
The C14 is a great bike, but it is also a big, tall, heavy bike.  There are lots of very good bikes out there that weigh less and have lower seat heights.  It might be worth checking them out before spending your money.
I think the C14 could work for you, but if the flat-foot thing is truly a no-go for you, well, you know.
Eyes, Brain, Hands.  Repeat.
Offline blue14
« Reply #10 on: June 30, 2012, 04:28:36 AM »
4" is likely much more than you need.  The turnbuckle type link lets you adjust until you get what you need.  Sounds like an inch or two would be plenty.
Offline chipmaker
« Reply #11 on: June 30, 2012, 04:54:20 AM »
The link above addresses the rear, but how could u lower the rear 4" and not touch the front??
2012 Ram Express
2012 C-14
2010 Camaro 2SS/RS
Offline blue14
« Reply #12 on: June 30, 2012, 05:44:10 AM »
Fork stops. Not ideal.
« Reply #13 on: June 30, 2012, 07:24:43 AM »
Looks like you didn't read the lowering thread I offered, at all.  Oh well; I tried.  Good luck.
« Reply #14 on: June 30, 2012, 07:42:51 AM »
« Reply #15 on: June 30, 2012, 07:48:11 AM »
I have a 30 inseam, at least that's the pants I wear.  I might be a bit less than that, though.  I wasn't totally flat footed with the stock seat and adding a Russell put me up another inch or so.  If the wife is riding with me and we have full gear I can flat foot quite easily.  Other times not so much.  I'm generally leaning one way or the other.  Not much, but still leaning.  It's not enough for me to forego the experience.
If you have to be absolutely flat foot on this bike then it isn't for you, unfortunately.  Lowering it much castrates it depending on your riding style.  I like it a bit sporty in the twisties.  Lowering would really suck for my riding.  Why buy it to ride straights all the time?  You would be wasting your money.
« Reply #16 on: June 30, 2012, 07:57:44 AM »
FX
So with the Corbin install the rear brake lever is moved to the left side of the bike?    :o
Or is that your other right foot?    ;)
Offline blue14
« Reply #17 on: June 30, 2012, 08:01:11 AM »
I think he bought the bike in England. :o
« Reply #18 on: June 30, 2012, 08:23:03 AM »
Lowering an inch seems to be the most that is "safe" and "reasonable" and doesn't appear to pose any danger or reduce cornering much; at least on a gen2 with a non-heavy rider.  But I absolutely think lowering more than that is not just going to ruin twisties, but pose serious danger from bottoming out, pan scraping, front fender hitting.... stuff like that.
Not necessarily.  There are LOTS of loud, low-performance, low-tech, annoying, vibrationy, Harley-type bikes out there on the road... many of which would be completely inappropriate for "twisties", yet quite friendly for shorter legged people.   However, one might want a Concours for all the other things in which it is so much better than "cruisers"- smoothness, power, quietness, technology, reliability, style, weather protection.  Even if it means losing some cornering due to lowering.
Not everyone has the same riding goals.  I know you know that, I am not picking on your post.  I am just clarifying for those people who love to yell out "maybe this bike is not for you", wrongly thinking there are lower-height alternatives out there that retain all the things that a sport-touring bike can offer.  Personally, I would rather have no bike at all than some V-Twin thing.
« Reply #19 on: June 30, 2012, 08:25:54 AM »
:yikes:
