Author Topic: Shorter levers abound - but how about 'longer'?  (Read 1509 times)
Offline Baggerjohn
« on: June 18, 2012, 07:48:03 AM »
Is anyone making brake/clutch levers for our bikes which are a bit longer than the stockers? I went with a set of Phil's extended bars in order to facilitate the mounting of some electronics and need to move the clutch master cylinder inwards about half an inch. This is going to put the ball end at a bad location...so I need a slightly lengthened lever.
Checked Pazzo along with the rest of the usual suspects and they're either 'standard' or short length. Are the adjustables available in a longer version - and are they worth the money? Any other suggestions?
Offline Fretka
Re: Shorter levers abound - but how about 'longer'?
« Reply #1 on: June 19, 2012, 09:59:48 AM »
I'm right with you.....can't find doodly-squat when it comes to a longer clutch lever.
