Author Topic: back off xp brake light signal module  (Read 1937 times)
Offline joeski
« on: June 12, 2012, 10:54:47 AM »
Does anybody know if this can be installed on a c-14?  Manufacturer and dealerships are no help.  I installed it in the brake pedal wire to 10 amp fuse of tail light.  The tail light and brake light flash and go through the flashes continually.  How do I get the brake light alone to flash?
Re: back off xp brake light signal module
« Reply #1 on: June 12, 2012, 01:43:32 PM »
Which model do you have?  SD-XXXX
What directions came with it?
« Last Edit: June 12, 2012, 02:19:01 PM by VirginiaJim »
« Reply #2 on: June 12, 2012, 02:05:57 PM »
I think that a diode has to be installed in the circuit someplace.
