Author Topic: Cross threaded front axle bolt  (Read 3197 times)
« on: June 12, 2012, 07:23:41 AM »
I've changed every tire on my 08 and after 79,000 miles that has to be at least 10 fronts without any problems so how the heck did I manage to cross thread my front axle bolt this time?
Exactly as I have always done, I re-installed the axle after removing the wheel for tire work so I could put a jack stand under it. But it only wanted to turn in about a 3rd of the way. I knew better than to force it and turned it back out. I was able to clean up the buggered threads and the wheel is back on and the axle fully torqued with about 2/3rd of the threads intact. With the pinch bolts properly torqued I do not belive this is a safety issue but I have a new bolt ordered anyway. $30.00 plus shipping.
Offline Cold Streak
Re: Cross threaded front axle bolt
« Reply #1 on: June 12, 2012, 08:50:43 AM »
Probably got some debris on the threads that messed it up.  It's pretty hard to get that bolt misaligned.
« Reply #2 on: June 12, 2012, 09:07:22 AM »
That is what I think. I am usually careful about debris but...
Offline Tarheelbob
« Reply #3 on: June 12, 2012, 09:21:13 AM »
You're talking about the aluminum "nut", right? The holder for the axle?
Did the exact same thing on my last tire removal/install. That aluminum holder is about the softest alunimum I've ever seen. While I never had a problem before, I cross-threaded it big time on this attempt. Much easier to get crossed than I thought. Made a mental note to really lossen things up on the axle install and work hard to let the holder find its center before putting any torque to anything. Like you, a $30+ lesson learned.
Offline chap
« Reply #4 on: June 12, 2012, 09:35:08 AM »
Good decision to replace the bolt. You have alot riding on the bolt not failing. Cheep insurance. I am definately a fan for replacing any suspect components,especially on a bike I am riding.
2010 Concours ABS = Blue
2003 Concours - Red (sold)
« Reply #5 on: June 12, 2012, 09:48:07 AM »
It sounds more like galled threads than cross threading. On a fine thread bolt, it cannot cross thread once the thread is engaged more than one full turn so if it went on correctly for 1/3 of the travel, it just is not possible for the nut to cant against the axle enough to mangle the threads.
When I change mine, I leave the nut in place and tightened by the pinch bolts; when I re install the axle it is aligned before it ever gets to the nut on the far side. So far I have not had any reason to remove the nut on the left side of the axle other than to coat it with anti- seize the first time I removed the front wheel.
« Reply #6 on: June 12, 2012, 11:23:19 AM »
I had never removed the nut myself until this occurred. Since you have to pull the axle out the right side anyway, I leave the left side pinch bolts tight to hold the nut. IIIRC this is opposite the manual instructions.
As for galling, I am sure you are right. Per your example, when I get my new nut I am going to slather it with body gylde coat it with anti-seize.
