Author Topic: SPARK PLUGS  (Read 6105 times)
Offline charliespain
  • Country: es
  • CARPE DIEM
SPARK PLUGS
« on: June 11, 2012, 04:47:19 AM »
Hello, someone has changed the spark plugs.
Images Step by step, please.
I know it's long and complicated, but sometimes pictures worth a thousand words
Thanks ¡
Re: SPARK PLUGS
« Reply #1 on: June 11, 2012, 05:01:48 AM »
How many miles on them?
  • Country: es
  • CARPE DIEM
Re: SPARK PLUGS
« Reply #2 on: June 11, 2012, 05:31:44 AM »
15.000 Milles.
But my question is not how many miles to be changed?
 I ask, on step by step pictures
Re: SPARK PLUGS
« Reply #3 on: June 11, 2012, 05:36:34 AM »
http://www.angelridevideos.com/concours.html
Fred Harmon's maintenance videos will guide you through a valve check. You can stop when you get to the spark plugs.
Re: SPARK PLUGS
« Reply #4 on: June 11, 2012, 05:37:28 AM »
15,000 Milles.
He was just wondering, since modern spark plugs should last for a very, very long time (WAY beyond 15,000 miles).
Re: SPARK PLUGS
« Reply #5 on: June 11, 2012, 06:20:17 AM »
15.000 Milles.
You get more than you ask for here....
You can change them at 15k, but you are wasting time and money to do so.
We do not have a step by step pictorial on the installation of the spark plugs.  It's in Fred's Videos, though.  Good luck on the process.
« Last Edit: June 11, 2012, 07:17:42 AM by VirginiaJim »
Re: SPARK PLUGS
« Reply #6 on: June 11, 2012, 06:47:49 AM »
Almost as wasteful as a valve lash check at 15K
Re: SPARK PLUGS
« Reply #7 on: June 11, 2012, 10:52:41 AM »
15.000 Milles.
Kinda rude Charlie, maybe lost in translation?  As has been stated, changing the plugs at 15K is way too soon, 30K would be closer to a reasonable amount, but even that is early.  53000 miles on the bike, I wasted the $$ on plugs at 15 and 30, I still have them and they look like new, I will be reusing them when I hit the 75k mark, same holds true on the valve check.  The first valve check yielded some changes, the second showed no change so as far as I'm concerned things are good to go.  FWIW, my bikes is a do it all bike, commute, mountain twisties, 2 up, and twice a year to the track.  Heck, I even ride it in the rain and she gets a bath once a year weather (sic) she needs it or not ;D
  • Country: es
  • CARPE DIEM
Re: SPARK PLUGS
« Reply #8 on: June 11, 2012, 11:48:55 AM »
hey¡ son of papy
En primer lugar no hablo ni escribo inglés.
Hablo y escribo correcatmente español y frances.
Jamás me he mostrado  GROSERO ante cualquier consulta.
Posiblemente la traduccion de google translator haya sida la culpable.
Si alguien se ha molestado, pido disculpas.
Estas paginas de la KAWASAKI  (Concours en los USA) y GTR, ( en Europa) bien sean americanas, francesas, alemanas o españolas, son PARA AYUDARNOS ante cualquier duda que tengamos, y NUNCA  (NEVER, NEVER, NEVER), para resultar GROSERO y/o insultar.
Saludos desde el Norte de Africa
Offline Mister Tee
Re: SPARK PLUGS
« Reply #9 on: June 11, 2012, 12:07:10 PM »
What is a Spanish and French speaking person doing in North Africa?
Re: SPARK PLUGS
« Reply #10 on: June 11, 2012, 12:16:05 PM »
No idea if I was just called the son of a fatherless dog or not ;)  ;D ;D
But, I'm willing to bet it was a matter of the google translator that has led to the misconception.
OK, I just translated it, many thanks for the kind reply and I apologize for my reply to you.  All is good in ZG land ;D
Translated reply from Charlie,
"Hey son of papy!First of all I do not speak or write English.I speak and write Spanish correcatmente and frances.I have never been rude before any consultation.Possibly the translation of google translator has the guilty AIDS.If someone has bothered, I apologize.These pages of the KAWASAKI (Concours in the USA) and GTR (in Europe) well are American, French, German or Spanish, are to help us any doubt that we have, and never-NEVER, NEVER, NEVER to be rude and/or insulting.Greetings from North Africa"
Offline PH14
Re: SPARK PLUGS
« Reply #11 on: June 11, 2012, 12:45:02 PM »
French is spoken in around 30 African countries as either the first or second language. There are Spanish speaking cities in Morocco as well.
Re: SPARK PLUGS
« Reply #12 on: June 11, 2012, 02:39:12 PM »
French colonies and Spain just across the water....   Makes sense to me.
Offline lt1
  • 2008 C14
Re: SPARK PLUGS
« Reply #13 on: June 11, 2012, 03:09:33 PM »
Thanks ¡
Aunque la fabrica recomienda cambiar las bujia a los 7500 millas/12000k, realmente no es necesario.  Son de tipo iridium, y pueden durar hasta 50000 millas.  Mejor hacer la decision a los 15000 millas al inspeccionar las valvulas.  En muchos areas, la inspeccion de las valvulas no se requiere hasta 26000 millas.  Por eso, has recibido las respuestas.
En cuanto al cambio, no es tan dificil, pero seria mejor si conseguis un manual oficial, y tomas fotos al desarmar el plastico y de cado paso.  Hay DVD's de mantenamient disponibles en este sitio:  http://www.pbase.com/fredharmon/concours14, y varias fotos que quiza te ayuden tambien.
Eyes, Brain, Hands.  Repeat.
Offline C1xRider
Re: SPARK PLUGS
« Reply #14 on: June 11, 2012, 09:38:29 PM »
Getting to the spark plugs is harder than doing a valve adjustment, almost.  I checked mine at 24,000 miles, and they only needed to be re-gapped.
 The procedure is pretty simple.  Just remove all the upper plastic so you can get to the valve cover, remove the fairing support braces and brackets that are in the way, remove the stick coils (which is a major pain), then remove the spark plugs.
 If you search the forum for stick coil removal, you'll find some pictures I posted of what they look like.
It is a big job just to get to them, so I would wait until you do valve lash adjustment and throttle body sync.  Check them out all at the same time.
Offline lather
    • Louisiana Chapter MSTA
Re: SPARK PLUGS
« Reply #15 on: June 12, 2012, 07:04:30 AM »
Denso Iridium FAQ:
http://www.densoiridium.com/faq.php
Who knew iridium killed the dinosaurs?
Re: SPARK PLUGS
« Reply #16 on: June 12, 2012, 07:32:20 AM »
Technically it wasn't the Iridium.  It was the big rock it was buried in that supposedly did the damage.
Offline lather
Re: SPARK PLUGS
« Reply #17 on: June 12, 2012, 08:01:21 AM »
According to the FAQ the big rock was "composed almost entirely of the precious metal Iridium".
Re: SPARK PLUGS
« Reply #18 on: June 12, 2012, 08:03:52 AM »
Denso Iridium FAQ:
Um, I did...
Offline lather
Re: SPARK PLUGS
« Reply #19 on: June 12, 2012, 08:05:37 AM »
