Author Topic: LCD Display Hard to see in the Sun  (Read 7894 times)
Offline chap
« on: June 05, 2012, 11:30:10 AM »
On my 2010 ABS C14. If the sun is shining on my display I cannot read it with my poor worn out eyes. i am assuming it is either backlight issues with the display, or the dispaly is not a high visibility one. If increasing the backlight helps, what backlight LED's are you using to improve the daylight visibility?? When my display is unreadable my GPS is still quite clear.
2010 Concours ABS = Blue
2003 Concours - Red (sold)
Re: LCD Display Hard to see in the Sun
« Reply #1 on: June 05, 2012, 11:48:19 AM »
Living in the NW, I have no problems with the sun...
« Reply #2 on: June 05, 2012, 11:53:11 AM »
The LCD display on the C14 is sometimes prone to 'darkening' once the sun is shinning on them, mostly while parked and it doesn't even have to be that hot out. Once you get moving it seems to clear up. From your discription, this doesn't sound like what you're talking about though.
Offline chap
« Reply #3 on: June 05, 2012, 11:57:27 AM »
No its nothing to do with heat. It is just the direct sun on the display. If I change direction and the display is shaded the dispay is readable again
« Reply #4 on: June 05, 2012, 01:25:17 PM »
You need to turn up the brightness knob.   But seriously folks...I've never had a problem with mine.  Have you compared it to another C14 in the same conditions?
« Reply #5 on: June 05, 2012, 01:33:07 PM »
Offline chap
« Reply #6 on: June 05, 2012, 01:41:26 PM »
I haven't. there are not many (or any) of these new gen C14's around here. I was expecting to hear from others with the same issue. I was thinking about trying a brighter backlight, but it would be great to see the experience of others. just really need to see the trip meter, and fuel level so I get fuel before it stops running.
Offline RBX QB
« Reply #7 on: June 05, 2012, 02:14:58 PM »
That's just mean... (tho, the sun IS out right now).
Seem to recall a recent post about an aftermarket shield that fit the top of the gauges to help shield the displays... I'll see if I can find it.
2011 Concours 14 ABS
« Reply #8 on: June 05, 2012, 02:33:09 PM »
Some guys were making their own sunshades with an old helmet visor.
« Reply #9 on: June 05, 2012, 02:38:38 PM »
I've got the sunshade and to tell you the truth, it don't shade that much, at least from my perspective.  And you will know when you go on reserve.  Ain't no missing that warning message.
« Reply #10 on: June 05, 2012, 02:56:59 PM »
hijacks the whole bike
Offline JerBear
« Reply #11 on: June 05, 2012, 04:08:42 PM »
Are you wearing any type of sunglasses?  When I wear my amber colored clip-on's the display practically vanishes.  Gray color it is fine.  If you are not wearing sunglasses and it is hard to see it is glare or your eyes because with no shades, it is easy to see.
2008 C14 Non-ABS
« Reply #12 on: June 05, 2012, 04:40:07 PM »
Polarizing lenses play heck with LCD screens...
« Reply #13 on: June 05, 2012, 06:14:22 PM »
Never a problem with mine because my brightness knob goes to eleven..8)..but seriously folks...
Maybe one of those sun shields that are made for a GPS will help?
« Reply #14 on: June 05, 2012, 06:18:13 PM »
My 08 fades sitting in direct sun. Fades back in 10ish minutes on the move.
Offline chap
« Reply #15 on: June 05, 2012, 10:08:15 PM »
I have an amber lens on my Shoei helmet. If I raise it up I can see a little, but it is still basically blanked out in sunshine.
« Reply #16 on: June 06, 2012, 04:07:30 AM »
You really need to compare this to another bike.  I'm thinking there are certain displays that are less bright than others here.
« Reply #17 on: June 06, 2012, 08:29:11 AM »
If he can't see the display he's not going to see the flashing low fuel warning.    ::)
« Reply #18 on: June 06, 2012, 08:57:04 AM »
If he can't see the display then he needs to take it in to a dealer.  I've been in all kinds of weather with mine and never could I not see it, even in bright sunshine.  I believe that there is also a red light that comes on as a fuel warning.   :)
« Reply #19 on: June 06, 2012, 09:00:39 AM »
No red light till you do the clearing procedure by pressing the two buttons in the magical sequence. I just went through it this morn myself.    :)
