Author Topic: Console buzzing  (Read 4032 times)
Offline reesedp
  • Sail Army
Console buzzing
« on: May 31, 2012, 05:53:23 PM »
So I'm searching the site for the buzzing instrument panel fix, cant find it, and now need one of the dedicated SA's here to post the correct link with a properly snide comment please.  Mine has the "right at 3k rpm's" buzz that I can no longer stand. A KIPASS quip would be appreciated, and something to do with oil viscosity would make my day perfect..  Gracias!
2008 Connie BTW
Offline rcannon409
Re: Console buzzing
« Reply #1 on: May 31, 2012, 06:01:19 PM »
I made mine better by snugging up the hardware.  Much of my noise/vibration was from the plastic plate under the windshield.
Offline krsron
Re: Console buzzing
« Reply #2 on: May 31, 2012, 08:45:20 PM »
The buzz on my bike was between  2500-4000 rpm, used a piece of 1/4 x 4" rubber under the dash plastic to eliminate the buzz.
Re: Console buzzing
« Reply #3 on: June 01, 2012, 04:04:09 AM »
Possibly this....
http://www.zggtr.org/index.php?topic=7199.msg85243#msg85243
Could also be the front black plastic under the screen.  Some people have taken that off and put a piece of foam tape under it to stop the buzzing.  Can't tell you exactly because I've never done it myself.
Offline reesedp
  • Sail Army
Re: Console buzzing
« Reply #4 on: June 01, 2012, 05:04:05 AM »
I'll look at this.  I thought I had read at one time that someone had opened it up and shimmed the board in there somehow but darned if I can find it.  It sounds like a sewing machine!
Re: Console buzzing
« Reply #5 on: June 01, 2012, 11:11:36 AM »
I get confused between what was posted on the old site vs the new as well.  I'm going to do some data mining this weekend.  Maybe I'll be able to find some more info on it.
Re: Console buzzing
« Reply #6 on: June 01, 2012, 11:42:23 AM »
Hey these bikes can't be as solid as a HONDA, but at least KiPass prevents real probs
Offline Caffeinated
Re: Console buzzing
« Reply #7 on: June 01, 2012, 01:04:56 PM »
My annoying vibe noise was the mirror on the left side. I tightened the already tight screw on the bottom, and it seems to have stopped. The color matched part on the front was the issue.
2012 Black Concours 1400
Offline reesedp
  • Sail Army
Re: Console buzzing
« Reply #8 on: June 01, 2012, 01:53:20 PM »
Now I'm feeling better!  If I press hard on the speedo side of the console it goes away.  I would appreciate anything you find Jim.
Flathead
Re: Console buzzing
« Reply #9 on: June 01, 2012, 02:59:17 PM »
This the one you're referring to?
http://www.zggtr.org/index.php?topic=3505.msg40454#msg40454
Offline reesedp
  • Sail Army
Re: Console buzzing
« Reply #10 on: June 01, 2012, 07:17:09 PM »
THAT is the one I remember!!  Thank you Flat.  Now if I can squeeze the time in between lightning strikes this weekend...
Offline marku8a
Re: Console buzzing
« Reply #11 on: June 02, 2012, 09:23:31 AM »
I had the same problem. The fix at the link above worked for me.
Mark
2009 C14 Red
Offline Slvrvalk1
Found my buzzing
« Reply #12 on: June 02, 2012, 09:43:37 PM »
I have a 2010 C-14 to which I had mounted the Motax air wings.  I had the buzzing, and I added washers to the mounting for the instrument cluster, but the sound continued.  I took off the Motax air wings and replaced the stock screws and tightened them.  The buzzing has gone.  These screws are right next to where the rear view mirrors are mounted to the bike.  Check to see if they are loose.
Dave
