Author Topic: Cooling Fan not kicking in?  (Read 4114 times)
Offline Canada44
« on: May 26, 2012, 03:33:05 PM »
Please advise.
I went for a ride yesterday and noticed my fan not kicking in. I was above the half way point , 1 bar from going to the top in some  stop and go traffic. I rode down the shoulder of the road to keep bike from reaching the max bars and overheating. The temp dropped to 1 bar below half way or at the half point when the bike was moving. When I got home I let the bike ideal to see if the fan would kick in. I turned the bike off when the fan did not kick in. The gauge was 1 bar from max before I got nervous turned the bike off.
I have called the dealer to have them look at the bike but that won't happen until next Friday.  The water level for coolant is good just below max. I check the level this morning when bike was cold.
thanks for any help.
Paul
2010 C14
2010 ABS C14
Re: Cooling Fan not kicking in?
« Reply #1 on: May 27, 2012, 06:24:12 AM »
On my bike, the fan(s) don't kick in until one bar below max.  There are two of them, not one.  You won't see them kicking in until that point.  Yesterday I would stop at a light and it would hit one below max for a bit before the fans kick in.  If both fans aren't coming on it could be the sensor.
Myself, if I were testing without the benefit of the manual, I'd let it just hit max to make sure they weren't working before I became concerned.  Could be a relay, could be a fuse.
You can check the fans by disconnecting them and then applying 12v external power to see if they come on.
« Reply #2 on: May 27, 2012, 07:18:29 AM »
Last spring the fuse for my fans popped and the way I found out was that they would not turn on. I would suggest checking the fan fuse. On my bike, I just replaced the fuse, the fans then worked and continue to do so, and I have no idea why it happened. ?? It could have been something stuck between the fan blade and the radiator but there was no damage to the face of the radiator.
Please advise.
Paul
2010 C14
Offline CrashGordon
« Reply #3 on: May 27, 2012, 07:57:26 AM »
Wow, Jim, that seems hot. My fans start cycling at one bar over the half-way mark on my 2009.
Offline W14
« Reply #4 on: May 27, 2012, 08:50:20 AM »
I have an 09. My fan works pretty much as Jim's, one/two bars below the top.
« Reply #5 on: May 27, 2012, 09:33:09 AM »
My fans work correctly, yours do not.  ;)
« Reply #6 on: May 27, 2012, 09:47:35 AM »
Mine too.....Jim has a retarded bike.
« Reply #7 on: May 27, 2012, 09:54:16 AM »
Both you and Conrad have thumpings due when I head out your way in July.
Offline Canada44
« Reply #8 on: May 27, 2012, 10:12:26 AM »
Thanks for the reply guys.
I will check the fuse.  love this forum  8)
cheers
C44
2010 ABS C14
« Reply #9 on: May 27, 2012, 10:40:32 AM »
Better pack a lunch Robin!
« Reply #10 on: May 27, 2012, 11:07:19 AM »
« Reply #11 on: May 28, 2012, 07:31:38 AM »
Hey now! What did I do this time?
« Reply #12 on: May 28, 2012, 09:27:52 AM »
General principles...
« Reply #13 on: May 29, 2012, 04:48:27 AM »
I thought that you were a Knight, not a General?
« Reply #14 on: May 29, 2012, 05:02:25 AM »
You see?  That's why.
« Reply #15 on: May 29, 2012, 05:04:01 AM »
Point taken
Offline Awaz
« Reply #16 on: May 30, 2012, 07:48:01 AM »
I am not too far off from Conrad. I am around Springfield, IL. Maybe we can all meet up when you head this way!
2016 Ducati Scrambler
2008 C14
« Reply #17 on: May 30, 2012, 07:55:19 AM »
Maybe we can. Gary (Gpink) is down in you area too Awaz. Check the member map, seems that we have lots of new members in this area now.
