Author Topic: Brakes Dragging... Normal?  (Read 3319 times)
Offline Gearhead82
« on: May 22, 2011, 03:18:24 PM »
I have a 2 week old '09 non-abs with about 600 miles on it (just did first service yesterday) and I've noticed that the brakes, especially the rear one, make quite a bit of noise anytime the bike is moving. It sounds like the pads are dragging on the rotors. Is this normal/common on these bikes?
Offline Rawman
Re: Brakes Dragging... Normal?
« Reply #1 on: May 22, 2011, 03:52:53 PM »
There was a recall done on the rear brake to install a "guard" to prevent small rocks or debris from catching in the rear brake pedal causing the brake to drag and eventually, heat up enough to lock up the rear tire.  Check to see if your recall was done.  Also, some have reported even with the recall, debris can possibly still get in there and cause the rear brake to drag.
2009 Non-ABS
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« Reply #2 on: May 22, 2011, 04:08:55 PM »
My front brakes drag.  More specifically my front left caliper.  I have bled the system, have even replaced the caliper but to no avail.  Hopefully, you will find the issue with your rear brake.  Could be debris or possible wasn't bled properly.  If you blead it, remember that there are two bleeds on the rear caliper.
T.S.R.
Offline robbie
  • Tampabay, FL
« Reply #3 on: May 22, 2011, 04:38:35 PM »
My rear drags more than I thought it should but after looking at other c14's it appears to be normal on this model.
2009 Kawasaki Concours 14, 2003 Goldwing, 2002 Goldwing, 2015 F-150, 2018 JK Wrangler, 2002 TJ Wrangler
Offline Gearhead82
« Reply #4 on: May 22, 2011, 07:06:34 PM »
Ok I'll check into the recall and bleed the brakes. Thanks for the responses.
Offline Rawman
« Reply #5 on: May 22, 2011, 07:12:54 PM »
BTW, the recall was for '08 and '09 only.....
2009 Non-ABS
