http://www.sears.com/craftsman-51-pc-max-axess-mechanics-tool-set/p-00929309000P?prdNo=1&blockNo=1&blockType=G1
I bought this set a couple of weeks ago and I finally got to put it to use yesterday when I bled/flushed & filled the brakes on my Silverado.
This is a very high quality set of tools and I give it the Conrad seal of approval. (High praise indeed)
Imagine using a ratchet to loosen/tighten your brake bleeders while you have your Motion Pro brake bleeder hose hooked up to the bleeder nipple. Yep, the hose passes right through the socket and ratchet. This combo is about as low profile as you can get and it'll get into those hard to reach places where other ratchets would never fit.
I'm thinking that it may make it easier to get at Connie's exhaust header nuts.
The set comes with lots of adapters that allow you to use standard sockets and universal joints along with it.
There are only two negatives that I can see thus far. Made in China and the ratchet handles could use a bit of knurling, they can get a bit slick.
"Product Description
This set features an ultra thin-profile design which fits over long bolts eliminating the need for deep sockets.
Ratchet strength is up to 45% stronger than our most popular ratchet.
This set comes in a convenient and portable briefcase style plastic carrying case.
Contents include 42 sockets, hollow shaft handle, 2 Go-Thru ratchets, 3 standard socket adapters, 2 extensions and a Go-Thru adapter.
This set is versatile and can adapt to all standard socket sets. Backed by Sears Craftsman Lifetime Warranty."
http://www.youtube.com/watch?feature=player_embedded&v=xVnIwAaxolM#!
