Author Topic: Quick video of how a single sided Muzzys sounds on my C14  (Read 37231 times)
« on: May 18, 2012, 07:08:40 PM »
The parking lot is small otherwise I would have given it some more throttle.
Concours 14 with Muzzys Full Exhaust (single sided)
Offline daringdave
Re: Quick video of how a single sided Muzzys sounds on my C14
« Reply #1 on: May 18, 2012, 07:26:19 PM »
That sounds deep and throaty... pretty awesome.
2010 Neptune Blue
Offline rydbaby
  • 2011 C14
« Reply #2 on: May 19, 2012, 07:22:32 PM »
Sounds great Jeremy - like a sports tourer should!  Did you get it re-mapped or whatever they recommend when you change exhaust?
« Reply #3 on: May 19, 2012, 08:38:32 PM »
 8)    :thumbs: :thumbs:
« Reply #4 on: May 19, 2012, 09:16:53 PM »
Yes, I have a PCV and AutoTune.
Taff
« Reply #5 on: May 19, 2012, 10:24:40 PM »
That is a real nice sound  ;D
Offline daringdave
« Reply #6 on: May 25, 2012, 02:34:44 PM »
All I can say is, "Jeremy, it is ALL your fault." After hearing your slip-on Muzzy, and even knowing that it will sound different in person, I want one!!
My 2010 Connie doesn't have any performance mods, and I don't ride to the bike's potential. I am not looking for more HP, but I like the sound of the Muzzy... that said, do I NEED to add a power commander, PCV, or autotune to correct any fuel mixture changes? Other reasons?
Seems to me the 2010 has an ECO mode, which controls the mixture already... won't the ECU correct the fuel/air mix automatically?
thanks for the help.
dave
2010 Neptune Blue
« Reply #7 on: May 26, 2012, 08:03:03 AM »
To be on the safe side you would want to add some sort of tuner (I am partial to the PCV/AutoTune combo) or a reflashed ECU from GUHL or Dynotronics.  There just happens to be a great deal on an exhaust exactly like mine.  Here is the link.
http://www.zggtr.org/index.php?topic=8921.0
Offline daringdave
« Reply #8 on: May 26, 2012, 10:45:58 AM »
Thanks, Jeremy, for the advice. I now understand that the free-er flowing zx14 (bigger pipes) would need a pcv/autotune. Would this also be true if I simply got a C14 slip-on Muzzy (or any other slip-on that uses the stock header pipes)?
BTW, this is probably a stupid question... but, does changing mufflers void my warrenty?
2010 Neptune Blue
« Reply #9 on: May 26, 2012, 02:00:31 PM »
No tuner needed for a slip-on. And as long as Kawasaki can't prove that your modification directly caused a failure you should have no warranty issues.  I have done quite a bit of work to my bike and have never even been questioned when it came time for a warranty claim.
Offline daringdave
« Reply #10 on: May 26, 2012, 03:26:59 PM »
Thanks for your help. I am now in the market for a Muzzy CF slip-on... woo hoo!
2010 Neptune Blue
Offline TJ
« Reply #11 on: May 27, 2012, 12:47:21 PM »
How much lighter is the Muzzy compared to the stock can?
2012 Black Kawasaki Concours
« Reply #12 on: May 27, 2012, 01:37:03 PM »
24 pounds was what I measured with my bathroom scale.  The stock header is also quite a bit heavier than the Muzzy version due to the catalytic converter, I didn't weigh the individual items but I would guess that the just the slip-on vs the stock bazooka would be around 15-20 lbs difference.
Offline TJ
« Reply #13 on: May 27, 2012, 01:50:51 PM »
20 pounds would be almost a 3% weight loss, that is worth the price of admission by itself:)
« Reply #14 on: May 27, 2012, 02:06:54 PM »
No other choice IMHO other than Area P and Muzzy, sounds great Jeremy!
« Reply #15 on: May 27, 2012, 03:20:43 PM »
Squid. ::)
 8)
« Reply #16 on: May 27, 2012, 04:34:01 PM »
Squid. ::)
 8)
Strong words from a guy that "tried" to do a burnout in front of a bunch of Harley riders and barely even managed to get the rear tire to spin.    ;D
« Reply #17 on: May 27, 2012, 04:49:32 PM »
Owned!!!!!!! :rotflmao:
Offline daringdave
« Reply #18 on: May 27, 2012, 07:16:44 PM »
What's a squid?
2010 Neptune Blue
« Reply #19 on: May 27, 2012, 08:08:03 PM »
