Author Topic: Mix and match oil pans  (Read 1783 times)
Offline shibby_cbs
« on: May 18, 2012, 02:00:17 PM »
so i just baught an oil pan that came off of an 06 connie to replace the one on my 86. from what i understand the motors are the exact same but i dont know that for a fact. am i going to run into any issues?
Offline CRocker
Re: Mix and match oil pans
« Reply #1 on: May 19, 2012, 08:14:14 AM »
Same part number for both years...shouldn't be a problem...
« Last Edit: May 19, 2012, 07:26:19 PM by CRocker »
'02 C-10
Offline shibby_cbs
« Reply #2 on: May 20, 2012, 11:21:57 AM »
alright great thanks....didnt think to check that
« Reply #3 on: May 20, 2012, 12:17:31 PM »
although the parts are interchangable, I will say that without a doubt (as i had an issue) the 86 and 88 bikes bottom pan had some slight casting differences in the area / recess the filter occupies. I found this out when I got one of the original SPOOFAK's from Dan, prior to his re-design of the adapter. The oil pan recess on the old bikes had a slight taper, and would wedge up the adapter before it got completely screwed home. So, as a warning, there are slight differences, but it doesn't matter, as Dan has redisigned the SPOOFAK...... ;)
if you are running a stock filter, you will not see the difference either. ;)
Offline shibby_cbs
« Reply #4 on: May 21, 2012, 04:22:02 PM »
this is good to know...but i wonder why kawi changed it seeing as seemingly it makes no difference
Offline Outback_Jon
« Reply #5 on: May 22, 2012, 07:54:42 AM »
Probably some accountant and some engineer agreed that they could make the part with a little less material.  Over however many number of bikes, Kawasaki probably saved some $$.  (I don't know for certain, but the oil pan may fit other models, too.)
Offline snarf
« Reply #6 on: May 22, 2012, 10:05:11 AM »
I bet it would fit on a ZL1000
2002 Conc
1986 Conc "The spirit of COG"
Offline Stasch
« Reply #7 on: May 22, 2012, 02:04:13 PM »
It fits 95 - 98 GPZ 1100's (ZX1100E) too.
