Author Topic: Planning on using a JCW or Sears trunk on a Givi mount?  (Read 2768 times)
Offline philipintexas
    • Phils Farkels
« on: May 22, 2011, 01:54:44 PM »
I just had the opportunity to measure the mounting pin placement on a JCW mounting plate. The 2 forward pins are approx. .082" further apart than the spacing of Givi's pins. That's a lot! Some of you have succeeded in getting the trunk to fit a rack with Givi or SW-Motech pins but I don't think that's a very close fit. They will work fine if you use the supplied mounting plate.
