Author Topic: Compact Nautilus Air Horn  (Read 7107 times)
Offline pilotsailing
« on: May 16, 2012, 06:26:26 PM »
Got a Compact Nautilus Air Horn from murphs kits, now I am wondering where to mount it. Does anyone know if it will fit under the front cowling somewhere ?  ???
Offline Lodogg2221
Re: Compact Nautilus Air Horn
« Reply #1 on: May 16, 2012, 08:49:02 PM »
It should.  I was going to mount one in there, but found a better option for me anyway, sound wise....trouble is, I have to find a place to mount 4 horns now.
If I cant, Ill get another Stebel.
When I had the left side pocket/plastic out, it seems to me there was a nice area in there to mount one.  Id imagine its the same on the other side.
Oh, and while we are on the subject, sometimes Harbor Freight puts them on sale for $30.  Its called the Bad Boy there, but its the same horn.  I had one from Murphs and two now from HF, all exactly the same....except the HF has a pretty chrome cover on part of it.
Say what?
« Reply #2 on: May 17, 2012, 04:17:28 AM »
Thanks for the info, I didn't want to take everything apart if it wasn't going to fit. I'll give it a try now.
Offline ManWorkinghere
    • Avatar database
« Reply #3 on: May 17, 2012, 09:32:21 AM »
I am very interested in your results.  My C-10 could use more 'cowbell'.
 :thumbs:
« Reply #4 on: May 17, 2012, 12:49:59 PM »
I guess i'll have to get at it then.
Offline timsatx
« Reply #5 on: May 18, 2012, 06:55:14 AM »
Yeah, I need to upgrade mine. I had to use the horn a couple of days ago and was really disappointed in its performance. On my Nighthawk I installed some Fiamm Freeway Blasters and what a difference they made.
    • Avatar database
« Reply #6 on: May 21, 2012, 09:08:41 AM »
While we wait for PilotSailing to do his Nautilus-ectomy, I have a question.
Could you take a Fiamm Blaster horn and replace one original horn without changing wiring at all?
Could you take a Fiamm and replace one horn, but have to replace wiring?
Looks like a Fiamm horn could attach, as is, under the fairing front.
What say y'all?
Offline Lodogg2221
« Reply #7 on: May 21, 2012, 03:26:51 PM »
Well, the web site says they draw 5 amps each, for 10 total.  No sense only using one, the dual tones are more of an attention getter than the single.
Most sites though say they draw more than that, so you will want a relay in there.
Ive got to tear into mine soon, to see where I can shoehorn 4 horns in the fairing....not sure if they will all fit where I want, but it will be impressive once done!
Say what?
Offline timsatx
« Reply #8 on: May 21, 2012, 11:00:53 PM »
Yeah, you want a relay with any of these horns. You also want to use the dual-tone setup. It is quite the attention getter. I will have to sit down sometime to figure out how to mount them.
    • Avatar database
« Reply #9 on: May 22, 2012, 09:30:21 AM »
OK, what kind of relay to use here?  Radio Shack have 'em?  I appreciate the sharing of knowledge.
Offline timsatx
« Reply #10 on: May 22, 2012, 09:51:14 AM »
    • Avatar database
« Reply #11 on: May 23, 2012, 06:34:42 AM »
Very enlightening link.  Thanks much for the reference.
Looks like I need to get me one of these from AutoZone.
Santech/5 pin 12 Volts universal SPDT relay with bracket
Price: $6.99
Part Number: MT0223
Offline crossj_2002
« Reply #12 on: May 25, 2012, 05:13:47 PM »
I put one of these on that I bought from Murph's.  I knew the stock horns weren't cutting it when riding in formation with a cruiser, I saw his left saddlebag cover start flapping loose.  Then I tried pulling up next to him and honking to get him to pull over.  He didn't even hear me.
Anyways, my Nautilus is installed in the triple tree.  Just with some heavy duty zip ties.  It works so much better than stock.
I also got the plug and play harness that he sells which includes a relay and instructions.  http://www.murphskits.com/catalog/product_info.php?cPath=25&products_id=194
  COG#9120 '99 C10 Concours
Offline dvitous
« Reply #13 on: June 06, 2012, 07:43:46 PM »
I bought the Harbor Freight "Bad Boy" horn - which is the same exact horn as this.
Just a tad too big to fit where the original horn was in my new Jeep.
It came w/ a 30amp relay - which although the instructions say isn't required for the jeep... it blew the 10a fuse in nothing flat.  If I do end up putting it on the jeep, I'll use the relay.
In the meantime... if I find a good place to mount on the bike.....  :o
Dan Vitous
Naperville, IL
Offline Gitbox
« Reply #14 on: June 11, 2012, 06:37:29 PM »
Hey cross, isn't your speedo cable supposed to go inside the wire loop next to the brake line splitter?
2008 Yamaha FJR1300A
2004 Yamaha FJR1300 (sold)
Offline crossj_2002
« Reply #15 on: June 17, 2012, 08:46:17 AM »
I thought so too, but I read on the main COG forums that the little clip there was only for the brake lines.  I can't recall who posted it.  This way seems to have less binding going stop to stop on the steering.
