Author Topic: PCV quick shifter  (Read 8280 times)
Offline Daytona_Mike
Re: PCV quick shifter
« Reply #20 on: July 12, 2013, 05:44:11 PM »
Thanks for the replay. I have just came back from a short ride. Everythink feels just fine know. Come to find out, default setting for the pressure switch was set normally closed at the software . After changing the state to normally open took care of the problem. .
sunnycoaster,
Did you mean to say change it from the default setting of  normally closed to normally open?
Offline sunnycoaster
« Reply #21 on: July 12, 2013, 07:45:56 PM »
My Quickshifter switch 4-114 is normally closed (resting), however I assumed that it would be normally open and when pressure was applied when changing gears it would close the circuit in the switch.
But the switch is a normally closed type so I changed the setting in the software to "normally closed" and it worked perfectly.
Cheers,
Sunnycoaster.
