I just looked at my checking account, if all goes well, I MIGHT be able to get these:http://www.ebay.com/itm/OHLINS-FRONT-FORKS-BENT-DAMAGED-PARTS-MULTISTRADA-S-MTS1000DS-MTS-1000DS-Y-/170783323284?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item27c37ab494
I have the Ohlins rear and the Traxxion cartridges. I think the Ohlins improved the rear more than the Traxxion improved the forks. If I knew I could get the ZX14 Ohlins forks for 1,000 more than the Traxxion cartridges I would have went that way, but the Ohlins rep I spoke with never mentioned it and I did not think to check it. Let us know how it works out Jay.
It would be very nice to have the full Ohlins fork setup, and if I ever have enough money in the bank to justify such an extravagant modification I would do it in a hearbeat.
It would be very nice to have the full Ohlins fork setup, and if I ever have enough money in the bank to justify such an extravagant modification I would do it in a hearbeat.@Spanky: Have you set the sag and played around with the settings on your AK-20?
Jay, it's a good thing you don't own a harley or you be pushing six figures in farkles by now.
I haven't but a suspension pro did .
I think the Ohlins are beautiful, and it would be fun to have a set for a conversation piece. But, I not sure its warranted with this bike. If you selected a spring rate for riding alone on the bike, its going to be way soft with a passenger and gear. If you compromise and pick a stiff spring, your back to being off...just like you started with.
The forks will be beautiful, and I'll bet you love them, but....Dont you need Brembo or works Nissin calipers as well? Even though the stock brakes are great, the look just wont be right. It would be like having a peanut butter and roast beef sandwich, instead of jelly.
www.kyleusa.com
Install was easy breazy. The fork is already prepped for the ABS sensor direct from Ohlins, although mine is a non-ABS model. Many thanks to Dan Kyle at Kyle Racing www.kyleusa.com for being so willing to make the spring swap work.
The reflectors threw me off though.....
Indeed, lose those goofy oem reflectors bro...
And the accessory lights are cool?
