Author Topic: A look at a damaged front caliper  (Read 2709 times)
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« on: May 22, 2011, 07:20:13 AM »
You may remember from before the crash that I had a stripped brake retention pin that allowed one of the four pads for my left brake caliper to fall out causing issues.....Here is a look at what happens.
Damaged piston
side view of piston notice the angle of grind.  I'm suprised that it didn't pop the piston out.  I rebuilt the caliper replacing seals and piston, the bore wasn't marred.
T.S.R.
Offline robbie
  • Tampabay, FL
Re: A look at a damaged front caliper
« Reply #1 on: May 22, 2011, 10:56:15 AM »
That's amazing, as I said before you were very fortunate this didn't turn out worse.
2009 Kawasaki Concours 14, 2003 Goldwing, 2002 Goldwing, 2015 F-150, 2018 JK Wrangler, 2002 TJ Wrangler
« Reply #2 on: May 22, 2011, 11:07:05 AM »
Couldn't agree more.  Like I said, I am suprised the piston didn't pop out.  By the way, rebuilding the caliper is actually quite easy.
T.S.R.
