Author Topic: Looking for a GF30 relay (Stebel PnP kit from Murph's)  (Read 3923 times)
« on: April 29, 2012, 08:15:49 PM »
I installed a Stebel Nautilus last year, using Murph's PnP kit.  The relay included with the kit is a GF30 (5 pin) and I can't seem to find it locally.  The closest thing I have found is this one.
http://www.primelec.com/gm-relay-13500128
It looks close but this picture shows the narrow male connectors, where my GF30 has the normal sized male connections.  Are there two different GF30 relays?  I sent an email to Murph to see if he could help.  If anyone has a suggestion to point me in the right direction I would really appreciate it.
Re: Looking for a GF30 relay (Stebel PnP kit from Murph's)
« Reply #1 on: April 29, 2012, 09:40:00 PM »
Just a square relay with 5 standard size plugs?
I can bring you one this coming weekend.
« Reply #2 on: April 29, 2012, 10:08:58 PM »
I'm not sure about the "GF30" but I do believe that any automotive 12v SPDT (5 pin) relay will do whatever the one that came with Murph's kit will do. Most likely available locally at Auto parts stores, however Murph sells one and his seems to come with a socket as well: http://www.murphskits.com/catalog/product_info.php?manufacturers_id=6&products_id=221
Offline Rick Hall
  • Eruption
« Reply #3 on: April 29, 2012, 10:26:49 PM »
One of these? The two larger lugs are 1/4" spade, the three smaller are 3/16" spade.
I've got a couple floating around in my basement.
Rick
Edit: From the OP website link, what about one of these:
http://www.primelec.com/tyco-12-volt-dv-spdt-automotive-electrical-relays-p7237829
http://www.primelec.com/dodge-chrysler-jeep-omron-automotive-electrical-relays-p7237974
« Reply #5 on: April 30, 2012, 11:21:37 AM »
Rick
That is what I am looking for, I didn't even notice that that there were different sized spades on the relay.  I will go ahead and and order a couple.
Offline RBX QB
« Reply #6 on: April 30, 2012, 11:42:22 AM »
Any auto parts store carries these, they are standard fare. Cheaper online, I'm sure, but they're common if you need one right away. I think I have about 5 in my toolbox right now.
2011 Concours 14 ABS
« Reply #7 on: April 30, 2012, 03:10:24 PM »
I checked at Oreilly and AutoZone yesterday and neither of them had one in stock.  I will check Napa and the Honda dealer this week.
« Reply #8 on: May 01, 2012, 04:07:11 PM »
Found the correct relay at Napa for about $6.  My Stebel can be heard over the Muzzy now.   ;D
