Author Topic: 2010 C14 ABS Rear Brake  (Read 5376 times)
Offline chap
« on: April 28, 2012, 12:48:32 PM »
I have just brought a 2010 C14 ABS bike. I have a question about the rear brake. I seem to have to push the pedal a long way compared to my '03 C10 bike. Is it possible to make it engage quicker. I guess I can get used to it, but it would be nice to have a quicker response. The bike has 1400 miles on it, so nothing should be worn out. Any comments. Thanks
2010 Concours ABS = Blue
2003 Concours - Red (sold)
Offline capt chaos
Re: 2010 C14 ABS Rear Brake
« Reply #1 on: April 28, 2012, 01:28:38 PM »
There are 2 modes available. Page 44 in my EU manual in the "Multifunction Meter" section. This appears to change the "link effect" to the front brake  ;) Must admit mine has a different feel to my GSX-R  ;)
2010 GTR1400 Magnesium
Offline KawiMick
« Reply #2 on: April 28, 2012, 02:17:42 PM »
Do you have a service manual?  There is a spec for the height of the brake pedal:
Brake Pedal Position Inspection •Check that the brake pedal [A] is in the correct position.
Footpeg
Pedal Position
Standard: About 45 mm (1.8 in.)  below top of footpeg
If it is incorrect, adjust the brake pedal position.
When my bike was new, I had to lower mine, it was way higher than I was used to.
Mick
'84 R100RS Pearl White Last Edition
'93 K1100LT Astral Blue Metallic
'96 R1100RT Sine Blue  Tucson,AZ/Santa Paula,CA
'10 C14 Candy Neptune Blue         Born OK the First Time
« Reply #3 on: April 28, 2012, 03:31:45 PM »
The rear brakes on these Kwaks typically have more travel.  I would check the specs but I suspect it's normal.  You would need to compare to another bike to be sure, though.
Offline chap
« Reply #4 on: April 28, 2012, 03:58:17 PM »
Thanks for the replys. Yes I have the service manual. The height of the pedal seems right. It is just the distance I have to push the pedal to get the brakes to come on. I don't have access to another C14 to compare. I would say I have to push it twice as far as my C10, so when I am not thinking I dont push it enough. I tend to brake with my back brake the most. I see on here most of you use the front most. I would be concerned of slipping on gravel braking with the front, even though I have abs, I don't want to rely on it working, just as a backup in emergency stops.
Offline Makz58
« Reply #5 on: April 28, 2012, 04:21:59 PM »
Not saying you have an issue here but I also came from an 03 C-10 and find my C-14 rear brake to have no more or less travel  than 03...
C-14 2010
Offline wipfel
  • 2010 Concours 14 ABS
« Reply #6 on: April 28, 2012, 04:35:39 PM »
Mine feels the same way.  It seems I have to press it down much further than I would expect to get it to engage.
--If I could be anywhere right now, I'd still be out there, on my bike, in the wilderness.
Offline DGOLD
« Reply #7 on: April 28, 2012, 04:42:02 PM »
With the linked brakes I think you need to realize the front is engaging wether or not you are squezzing the front lever.
2010 c14(current mistress)
Offline KawiMick
« Reply #8 on: April 28, 2012, 05:13:07 PM »
First,
  Which mode are your brakes set to?  Normal or Enhanced?  It makes a difference.  The rear pedal feels different in each mode.
  Also, start braking with BOTH brakes.
Mick
Offline chap
« Reply #9 on: April 28, 2012, 10:04:30 PM »
I have my ABS setting in Mode 2 (suggested for touring). I agree and I do use the front brake, but always have applied the rear first, having such a big travel with the pedal i get the front on first so it is not what I am used to. We have alot of gravel on the roads here, and don't want to be in a situation where the front slips. It just isnt what I am used to. I think the procedure in the manual is for pedal height not preload of the hydraulics. am I right??
Offline KawiMick
« Reply #10 on: April 28, 2012, 10:06:26 PM »
Correct but they go hand in hand if the linkage and footrests are stock.
Offline chap
« Reply #11 on: April 28, 2012, 10:17:12 PM »
So if I go through the procedure in the manual, does the height of the pedal change, or the preload of the hydraulics. It looks like a bear to get to to adjust, so I wanted to know what will happen if I try it. By the way thanks so much for your advice.
Offline KawiMick
« Reply #12 on: April 28, 2012, 10:30:35 PM »
The pedal height only changes if YOU change it.  The brake application in the enhanced mode is based on pressure in the system.  If the sensors detect a certain amount of pressure in the rear circuit, it applies the front brakes.  Mode II should be very sensitive to rear brake application, mine is.  I mostly ride with Mode I.
Offline chap
« Reply #13 on: April 28, 2012, 10:43:34 PM »
I'll give mode 1 a try and see what the difference is. I like the height of the pedal where it is so I dont want to mess with that. I have a sneeking suspicion I may have to get used to it the way it is, or maybe try better brake pads
« Reply #14 on: April 29, 2012, 06:29:41 AM »
Many of the replies to your posting have nothing to do with your question.  It doesn't matter what mode the brakes are in or that they are linked.  It doesn't matter where the position of the pedal is.  You asked if it is normal for the ACTIVATION TRAVEL of the pedal is normal and if it can be adjusted.
To that, I would say that it does seem like the activation travel is a bit more than some bikes, and similar to others.  The rear brake pedal travel is not adjustable (I just checked the factory manual).  Assuming your brake system is in proper working order, you will just have to get used to it.
Offline So Cal Joe
« Reply #15 on: April 29, 2012, 07:22:13 AM »
I know its a new bike but have you thought about bleeding the system? Also for Gold Wing and other bikes  they make an after market pedal that goes on top of the stock pedal, you might try and make one for the Concours, or maybe if you have a motorcycle shop with a lot of accessories you might try one for another bike and see if it fits the pedal on the concours.
Offline chap
« Reply #16 on: April 29, 2012, 07:47:16 AM »
Thanks guys for your responses. Yes I think I will have to just get used to it.
Offline momo65
« Reply #17 on: April 29, 2012, 10:58:48 AM »
I believe that you should use your front brakes more than the back brakes , the front has the stopping power in case of emergency and should be your primary brake unless you are in a tight parking situation or garage ramp. just my two cents.
« Reply #18 on: April 29, 2012, 12:43:43 PM »
I use both front and rear brakes.  I paid for two so I use them both.  If you aren't supposed to use the rear brake, why have one at all?  I can certainly tell the difference using the front alone and the front and rear both.
« Reply #19 on: April 29, 2012, 05:27:36 PM »
Maybe it is due to the extra strong spring that seems unnecessary.  Remove the spring and see if that makes a difference.  It will not hurt anything to try this.
