Author Topic: Carbon fiber rear hugger  (Read 15373 times)
Re: Carbon fiber rear hugger
« Reply #20 on: May 10, 2012, 04:53:24 AM »
Offline Necron99
    • Facebook Page
« Reply #21 on: May 10, 2012, 05:28:53 AM »
This was an issue that some of us who participated in the group buy a couple of years ago had. We ended up ordering slightly longer bolts for those locations.
Do you recall the exact bolt and size you acquired to replace?  I wouldn't mind getting them in advance so I can do the project as soon as my hugger is in.
-Dylan Thomas
2010 ZG1400 COG #9384
« Reply #22 on: May 10, 2012, 08:32:17 AM »
Yep, I ordered em from Ron Ayers and here's the part numbers and size.
BOLT,SOCKET,10X67  Kaw # 92153-1944  Ayers part number 1100677
I bought some extra nuts at the time as well. (cuz I boogered up the originals)
NUT  Kaw # 92210-1139  Ayers part number 1107363
Offline Necron99
    • Facebook Page
« Reply #23 on: May 10, 2012, 04:15:33 PM »
How man of each are required?  2?  And I'm confused... I looked the part on Ronayres.com and they look like OEM parts from Concours... if the OEM part is too short, what am I missing?  Or is it that one side is too short?
92153A 92153-1943 BOLT,SOCKET,10X63
92153B 92153-1944 BOLT,SOCKET,10X67
I see the part you reference is the 92153B which appears to be 4 mm longer than the other side... so the 67 is good for both sides and I'd just need one?
-Dylan Thomas
Joncon11
« Reply #24 on: May 10, 2012, 06:01:49 PM »
Someone mention my name?
I see what you did there  ???
« Reply #25 on: May 11, 2012, 04:06:00 AM »
Are you comfortable with the softer stainless bolts in what may be a critical location?
« Reply #26 on: May 11, 2012, 05:17:11 AM »
I have some pics on my work PC, I'll show you what I'm talking about later today. If I remember.
« Reply #27 on: May 11, 2012, 06:52:26 AM »
Any hardness markings on the head?
http://www.k-tbolt.com/bolt_chart.html
http://www.columbusdsm.com/forum/showthread.php?t=16655
Code:
Inch  Marks   Material      Tensil Strength  Yield Strength
Grade on Head               N/mm2    psi     N/mm2    psi
2     none    Steel         510    74,000    393    57,000
5     3       Steel         827    120,000   634    92,000
8     6       Alloy Steel   1030   150,000   896    130,000
SHCS  none    Alloy Steel   1240   180,000   965    140,000
18-8  none    302 Stainless 690    100,000   448    65,000
316   none    316 Stainless 690    100,000   448    65,000
Metric Marks   Material       Tensile Strength  Yield Strength
Class  on Head                N/mm2    psi      N/mm2    psi
8.8    8.8     Steel          800    116,000    640    93,000
10.9   10.9    Steel          1040   151,000    940    136,000
12.9   12.9    Alloy Steel    1220   177,000    1100   160,000
A2-70  A2-70   302 Stainless  700    102,000    450    65,000
A4-80  A4-80   316 Stainless  800    116,000    600    87,000
« Reply #28 on: May 11, 2012, 07:12:28 AM »
Taff, stainless has it's place. I tend to err on the side of caution, especially when being wrong might mean being dead. I'm not an engineer or metallurgist so I don't know when 'good enough' might not be good enough. Others might disagree but to each his own.  8)
« Reply #29 on: May 11, 2012, 08:27:43 AM »
Conrad, any help for me and other folks deciding to do this mod would be helpful.
More opinions and knowledge, better outcome as far as I am concerned.
Jon.
Here's the pics of my install using the stock bolts.
left side
[smg id=242]
right side
[smg id=241]
As you can see using the stock bolts the nuts just barely get the last bit of threads on the bolts and it would probably be fine for anyone less anal than I am. If you use the part numbers that I posted earlier the 67mm bolts are just a tad longer and the nuts get all of the threads. Using a longer bolt than 67mm will work of course but there's no need.
Offline Cuda
« Reply #30 on: May 11, 2012, 10:27:10 AM »
We mount 400lb+ + outboard motors on jack plates sometimes 12 in. back , making 370hp with four SS 1/2 bolts and I never heard of one snapping.
Gods waiting room Naples
2011 Atomic  Silver
Offline Necron99
    • Facebook Page
« Reply #31 on: May 22, 2012, 02:40:00 PM »
UPS has my rear hugger.....  should be on my doorstep when I get home!
-Dylan Thomas
Offline wildnphx
« Reply #32 on: May 22, 2012, 03:12:37 PM »
On a side note - We need to talk!!  I blew up my outboard and am in need of another..  Now of any decent deals on a Merc 225 EFI or DFI?  or I would take a 200 powerhead only if price is right...
Send me a PM...  thx
Back on topic I was seriously considering a Carbon Fiber hugger to match my Muzzy Dual Carbon Exhaust but just can't bring myself to spend more money at this time...  Spent to much over past couple months not to mention my other love aka boat needs some attention :)
« Last Edit: May 22, 2012, 11:19:56 PM by wildnphx »
Offline Necron99
    • Facebook Page
« Reply #33 on: May 22, 2012, 03:52:22 PM »
LEFT TURN CLYDE!  lol
-Dylan Thomas
Offline Necron99
    • Facebook Page
« Reply #34 on: May 24, 2012, 12:34:17 PM »
So there's a step that was missed in the other guy's instructions, Taff was lucky enough to not have to remove his exhaust.   You'll see in my write out of this step how you can avoid it.
Install the stock exhaust.  Spend 15 minutes trying to figure out why the heck the mid pipe bolt won't go all the way through the hole.  Go inside and check the diagram on the shop manual.  Realizes that the back bracket goes INSIDE, not OUTSIDE.  Reinstall and the mid pipe bolt goes right through.
So...it only took me an hour or so (plus the extra enjoyment from the above step) to get 'er installed this a.m. before work.  Wanted to get it installed before bike night with my drinking buddies.  Large res available here - the file names without the "s": http://home.armourarchive.org/members/morgan/connie/hugger
« Last Edit: May 24, 2012, 01:57:43 PM by Necron99 »
-Dylan Thomas
Offline Cuda
« Reply #35 on: May 24, 2012, 08:16:13 PM »
Looks GREAT looking forward to getting one also .
2011 Atomic  Silver
