Author Topic: Pinch bolt boo-boo  (Read 5202 times)
Offline Awaz
Pinch bolt boo-boo
« on: April 24, 2012, 09:47:07 AM »
So, I got my front tire replaced, wheel balanced, and put it back on the bike last weekend. I was pretty stoked that I got all that done inspite of being a bit on weak side due to recovering from some health issue. With wife nagging NOT to take the bike out for test and my excitement, I forgot to tighten down the pinch bolts and out we went wheeeeeee!!! I kicked it to about 80 just to see how it feels. Then my nephew gets on and does a test ride - between the two of us no more than 15 miles. And the the bike sits until today, when I realized I have not tightened those darn bolts !! So, question is, how bad is it? Do not think I see anything visually bad.
2016 Ducati Scrambler
2008 C14
Offline wendel
Re: Fork brace boo-boo
« Reply #1 on: April 24, 2012, 09:52:57 AM »
Well you do not need to go through the trouble of rocking the front suspension to seat the axle ;D. I am not a mechanic but, I would think if you did not feel anything unusual, then everything is fine and you just need to go through the proper tightening sequence, ride and enjoy yourself. Bet you don't do it twice.
2012 C14
Re: Pinch bolt boo-boo
« Reply #2 on: April 24, 2012, 12:37:54 PM »
Come on now man! You can't blame this on the wife.    ;)
Offline Awaz
« Reply #3 on: April 24, 2012, 01:00:34 PM »
I cannot remember the last time 'I' made a mistake! It was always someone or something's fault !
Anyhow, I tighten them down and drove it to work. I was so paranoid, I had all kinds of odd feeling - kept thinking vibration, too much feel of the road, and more importantly, felt the bike was pulling to the right if I let go the handle bars (yep - did that)! At the parking lot at work, found out what was causing the pull to the right - right bag was full of junk ! lol !
2008 C14
« Reply #4 on: April 24, 2012, 01:10:24 PM »
Did the wife pack your bag for you?     :P
« Reply #5 on: April 24, 2012, 01:21:05 PM »
Too much junk in the trunk...
Offline Awaz
« Reply #6 on: April 24, 2012, 01:29:15 PM »
I take it is a double entendre  ;)
Too many martini ? :D
2008 C14
« Reply #7 on: April 24, 2012, 01:49:31 PM »
Sorry, I don't speak French.  And one can never have too many martinis.
« Reply #8 on: April 24, 2012, 01:51:50 PM »
Or double entendres.     8)
« Reply #9 on: April 24, 2012, 01:53:09 PM »
« Reply #10 on: April 24, 2012, 01:57:31 PM »
Thanks for sharing the story. You can bet I I will be double checking my pinch bolts the next time I have the front wheel off. I shudder to think what could have happened at 80 mph if the axle had come loose.  :yikes:
« Reply #11 on: April 24, 2012, 02:09:17 PM »
Head over heels perhaps and possibly immortalized on Youtube, assuming one of your buds was filming it.
Offline Awaz
« Reply #12 on: April 24, 2012, 03:01:25 PM »
No one was filming. If I died, wife would be rich ! lol !
2008 C14
« Reply #13 on: April 24, 2012, 03:20:39 PM »
Same with me, wife would be rich.
« Reply #14 on: April 24, 2012, 03:38:20 PM »
Just a heads up on the front axle pinch bolts...
I always use a torque wrench to tighten them. It says in the manual to go back and forth with the bolts until they both click without turning. It's solid advise, since they always need more after you tighten the opposing one.
« Reply #15 on: April 24, 2012, 03:40:36 PM »
You don't say? How rich exactly?    ;)
« Reply #16 on: April 24, 2012, 05:20:48 PM »
More than a dollar and less than the price of a current aircraft carrier.
Offline jtk1531
  • Country: my
« Reply #17 on: April 25, 2012, 11:35:33 AM »
the reverse happened to me once...
dealer tightened the pinch bolts but left the axle loose. finger loose, didn't even need tools to turn it after i loosened the clamp bolts.
they forgot to tighten the axle after changing tyres for me, and it didn't occur to me to check it again when i got home (too much trust on their workmanship at that time).
result: front wheel bearing failure within a week of tyre-change.
that was on a zx10r, much lighter than C14s.
Offline Awaz
« Reply #18 on: April 25, 2012, 12:51:28 PM »
Wonder which is worse....what was your symptoms on wheel bearing failure?
Also, I did not do the back and forth thing. I have been driving the great distance of 2 miles (sheeesh) to work. But I will check them out.
2008 C14
Offline jjsC6
« Reply #19 on: April 25, 2012, 01:42:42 PM »
If the axle nut is torqued down the pinch bolts don't do a whole lot anyway - at least not for a short term.  Long terms they could cause some issues for sure.  I'm pretty certain you would start to feel a little vibration while braking as the first sign of a problem.  That's my take on it - could be wrong.
Jim
2010 Concours - Sold Feb 2013
Current bikes....
