Author Topic: Brake lines  (Read 3198 times)
Offline TimmyG
Brake lines
« on: May 21, 2011, 07:48:28 PM »
Who makes the best brake line kits for our bike?
Re: Brake lines
« Reply #1 on: May 21, 2011, 09:13:08 PM »
I'm still running the oem lines on my Connie, but I've always run the spiegler lines on all my other bikes, excellent quality and fit!  :thumbs:
http://www.spieglerusa.com/brakes/cycle-brake-line-kits.html
Taff
Re: Brake lines
« Reply #2 on: May 21, 2011, 09:53:12 PM »
+1.
Galfers are OK but the "banjo bolts" and brass flat washer need extra torque to stop the fluid from weeping at the joint. My friends use Spiegler mon their bikes and they seem to work well.
Jon.
Offline CrashKLRtoConnie
Re: Brake lines
« Reply #3 on: May 22, 2011, 08:11:41 AM »
Went to the spiegler web site  and only shows connie to 2007.
So no C14 brake lines?
« Last Edit: May 22, 2011, 08:49:42 AM by CrashKLRtoConnie »
2008 C14 GTR1400 AKA "Connie"
Offline Fretka
Re: Brake lines
« Reply #4 on: May 22, 2011, 12:16:20 PM »
My 2009 came with steel lines and has excellent feel, no mush at all. I kinda doubt that they could be improved on.
Offline Mister Tee
Re: Brake lines
« Reply #5 on: May 22, 2011, 12:18:55 PM »
My 2010 did not, and it feels quite mushy.
Offline Rawman
Re: Brake lines
« Reply #6 on: May 22, 2011, 04:23:29 PM »
I am pretty sure the OEMs are steel coated lines.  They are quite good.
2009 Non-ABS
Offline Mister Tee
Re: Brake lines
« Reply #7 on: May 23, 2011, 08:43:20 AM »
Maybe that was a change for 2010 then.  I'm quite certain mine are standard rubber lines.  I had nice OEM steel braided lines on the Beemer.  Those felt rock solid.
Offline TimmyG
Re: Brake lines
« Reply #8 on: May 24, 2011, 05:37:08 PM »
spielger doesnt havea kit listed who else has them? all i have seen is the galfer
Re: Brake lines
« Reply #9 on: May 24, 2011, 05:57:43 PM »
Did you try calling them TG? They will and do custom make lines for any bike, I had them do this for one of my bikes awhile back. Worth a shot, they're quality is superb IMO...
Offline C14PAINKILLER
Re: Brake lines
« Reply #10 on: May 26, 2011, 10:54:30 PM »
I like the HEL line that is out there. Don't have a kit for the Concours but for all lines including the clutch they said would be around $931 :pukeface:. Mind you that is for the '10 ABS model with linked braking, lots of lines. Plus if you are daring, you got lots of colors to chose from. I think I would  probably opt for the translucent red, hey Blanton it would finish off your masterpiece! 8)
http://www.h-e-lusa.com/MOTORCYCLE-BRAKE-LINE-INSTALATION.htm
2010 PAINKILLER BLUE   COG# 9405
Rides the metal monster, breathing smoke and fire
