Author Topic: TIRE R ----  (Read 2603 times)
Offline azul10
TIRE R ----
« on: May 20, 2011, 07:16:57 PM »
New 2010 concours displayed from the git-go . New dealer 1 yr.  I think this is there first connie. I drove it home it alarmed low tire press F.  31 psi . I aired up to 41 . O K . But still no reading fpr rear tire press.  Tire F 41 psi Tire R ---.     Bad sensor ???? I am sure you guys Know more than my dealer. Want to pass your wisdom on.
Offline Rawman
Re: TIRE R ----
« Reply #1 on: May 20, 2011, 07:57:13 PM »
First try airing up to over 50 psi to "wake" up the sensor.  It is shipped in "sleep" mode so as not to drain the battery.  If that does not work, take the bike back to the dealer and have them check to see if the sensor was registered to the bike.  Sometimes the battery was FUBAR from the factory and should be replaced under warranty.
2009 Non-ABS
