Author Topic: Running power from the battery to the back...  (Read 2600 times)
Offline RideBellChain
    • RideBellChain.com Send a bell, receive a free bell!
« on: March 25, 2012, 03:52:55 PM »
Hi all,
I know there's ACC power in the back, but I need constant power (not from the ignition switch) for my LED accent lights and also for my Coocase trunk that needs power for the alarm.  I have the battery cover off, but don't see a clear path to run a wire easily, and I'm sure the guys who have had their Connies longer than me probably know a trick or two..or where I can tap into power under the seat.
I'm also going to need power to go to the relay for the Stebel horn that I want to mount as well...and if you guys can point me in the right direction, I'd really appreciate it!
Thanks in advance,
Mark
http://www.RideBellChain.com
2012 Black Concours 14....yep, the fast color!  :)
(Sorry if this has already been discussed, but I couldn't guess the right keywords to find what I need...)
Ride Safe!  Mark Turkel
2012 Black Kawi Concours 14, 2008 Yami Royal Star Venture
Re: Running power from the battery to the back...
« Reply #1 on: March 25, 2012, 03:58:54 PM »
I haven't run any wires backwards from the battery, so I can't help you there. For the Stebel I would highly suggest you get the harness from Murph.  It keeps the stock horn in the loop just in case your Stebel would happen to fail and it makes the install a painless process.
« Reply #2 on: March 25, 2012, 04:07:13 PM »
Hi Jeremy - Thanks for the quick reply - I appreciate. I've installed 3 Stebel Nautilous horns on my other bike and two friend's bikes...I had no issues with the wiring, and that's not an issue for me - I'm pretty good with that kind of stuff. I'm more interested in seeing installations and understanding how to best run the wires and where to mount things.
I'd love to see a pic or two on your bike of your horn setup - that would be really helpful.  :)
Thanks,
Mark
« Reply #3 on: March 25, 2012, 04:14:36 PM »
There are acc leads under the seat, under the ecu I think. Try this link:
http://www.pbase.com/fredharmon/accleads
Fred sells excellent maintance videos.
http://www.angelridevideos.com/
« Reply #4 on: March 25, 2012, 04:56:59 PM »
Thanks,
Mark
There are several different mounting setups in this thread.
http://www.zggtr.org/index.php?topic=3104.15
« Reply #5 on: March 27, 2012, 12:46:16 PM »
@gpink - the accessory leads are dependent upon the ignition being switched on, I believe.  I need power all the time for the alarm...if it only works while I'm on the bike, it's kinda defeating the purpose.  I'm just going to run my own lead, I guess...nobody seems to know the answer - but thanks for trying to help.  :)
I agree - Fred's videos are excellent!  I bought the update video to see how to take off the fairings on the new model, but after watching it I'm planning on buying the entire set.  Good stuff.
« Reply #6 on: March 27, 2012, 04:43:24 PM »
Consider a Fuseblock or similar addon to give you plenty of switched or unswitched power.
