Author Topic: Cigarette scocket loose conection  (Read 3474 times)
Offline Cuda
« on: March 25, 2012, 05:51:29 AM »
I have a new bike and a new Escort radar unit and under acceleration it comes unpluged ? any ideas? Thanks jj
Gods waiting room Naples
2011 Atomic  Silver
Offline jtk1531
  • Country: my
Re: Cigarette scocket loose conection
« Reply #1 on: March 25, 2012, 06:45:39 AM »
same problem here with my gps power connector.
i used some electrical tape and put a few layers around the cigarette lighter plug, right where the plug stops when it's fully inserted.
Offline koval68
« Reply #2 on: March 25, 2012, 06:46:18 AM »
Very common problem, rubber band around the plug should fix it temporarily.
Long term fix.....use a BMW style socket and plug.
- Mahatma Gandhi
Offline So Cal Joe
Re: Cigarette socket loose connection
« Reply #3 on: March 25, 2012, 07:59:28 AM »
I use a black flat wire tie, lay it in the socket, plug in the plug and cut off the excess. works great.
« Reply #4 on: March 25, 2012, 09:48:46 AM »
Easy fix, plug your radar plug in the socket, then wedge a toothpick in between the gap in the socket wall and the plug (use a flat head screwdriver or it will hurt your finger), then break off the end of the toothpick sticking out. Done! I had your same problem, did this and all has been well for a year and a half now, it's in there solid!
 :thumbs:
« Last Edit: March 25, 2012, 10:56:39 AM by ZG »
Offline erock
« Reply #5 on: March 25, 2012, 10:25:37 AM »
Great fix I've found is to attach a thin strip of the furry side of Velcro to the male portion. This tightens the fit enough so there is no movement or play to allow it to work out.
Tiny strip, less than a quarter of an inch.
« Reply #6 on: March 25, 2012, 01:51:24 PM »
BINGO......except I lined the socket instead. ;) This works great, fits nice and snug and has never come close to working its way out.
Offline BudCallaghan
« Reply #7 on: March 25, 2012, 11:21:15 PM »
A high quality radar detector isn't much good unless it's connected to a power source.  My '09 had the same problem no matter what was plugged into it.  My solution was to replace the stock socket with one purchased at an auto parts store.  It's a simple job and the stock rubber cover can be used with the replacement socket.
« Last Edit: March 30, 2012, 01:18:09 PM by BudCallaghan »
Offline Cuda
« Reply #8 on: March 27, 2012, 08:29:43 AM »
Man I'm doing this to ALL my sockets , just half the socket is all that is needed, kind of over did it on the first one ;D
2011 Atomic  Silver
« Reply #9 on: March 27, 2012, 09:47:52 AM »
Glad you gave it a try, I guess I could've told you how much to use. :( I just used a small strip at the base of the socket "top and bottom" now it is tighter than a mouses ear. :)
