Author Topic: Center stand removal?  (Read 7115 times)
Offline Cuda
« on: March 13, 2012, 08:17:23 PM »
Has anyone removed the center stand? I'll be installing a dual zx exhaust on my concours and I heard it  gets in the way, I don't see why I need it, so I may as well lose it.
Anything I need to know?
Also do I need to install new gaskets with the ZX headers or reuse the stock ones.
Thanks jim
Gods waiting room Naples
2011 Atomic  Silver
Re: Center stand removal?
« Reply #1 on: March 13, 2012, 08:48:27 PM »
You may need to know it is inconvenient to change tires and to do general maintenance on a 700 lb bike with only a side stand. I hate it with my 400 lbs SV650.
Offline Cuda
« Reply #2 on: March 13, 2012, 08:51:46 PM »
Someone must sell a rear lift of some kind. What do the ZX guys do they don't have a center stand.
2011 Atomic  Silver
« Reply #3 on: March 13, 2012, 09:28:20 PM »
I am sure there are lifts for front and rear. I have them for my SV but they are difficult to use without a helper. I have a big dent in the SV tank to prove it. :'(
My guess is the ZX guys that ride a lot of miles have aftermarket center stands.
If I had a lot more money or rode a lot less miles I could live without a center stand.
« Reply #4 on: March 13, 2012, 10:48:10 PM »
The ZX14 can use a swing arm stand, the Connie can't...  :(
Offline muguvian
« Reply #5 on: March 14, 2012, 11:41:17 AM »
I removed mine when I put on the dual exhaust.  When I change tires or wash it I'll put it back on minus the nuts and spring, takes about 3 min.
« Reply #6 on: March 14, 2012, 12:45:57 PM »
Muzzys makes a modified center stand for their dual exhaust, that's what I have, works great and looks stock.
Offline Gearhead82
« Reply #7 on: March 14, 2012, 01:45:52 PM »
Thanks jim
Yes, you will need new gaskets.  They're the same gaskets the ZX-14 uses so I had no problem finding them in stock locally.
Offline Kiwi Graham
  • Country: nz
« Reply #8 on: March 14, 2012, 02:47:06 PM »
I put the duel ZX14 system on mine, I added 80mm to the foot tang on the centre stand and it fits 'sweet as' total cost a slab of beer to the welder  :)
« Reply #9 on: March 14, 2012, 03:29:15 PM »
Kiwi, what's a 'slab of beer'?
Offline Kiwi Graham
  • Country: nz
« Reply #10 on: March 14, 2012, 03:56:48 PM »
Ha ha, Its a pack, box, carton or 'carry out' of beer. Bottles or cans, usualy 12 - 24 of the little beauties in each.
http://dieline.typepad.com/.a/6a00d8345250f069e20115703655ba970b-550wi
Offline Cuda
« Reply #11 on: March 14, 2012, 04:39:45 PM »
I have mig, tig, arc, that is not the issue , I like the IDEA of putting it back on when I have to ,because I won't have to do that very often, I have a wrench that works on my business stuff, so Thank You for that idea. Jim
PS how much does it weight ?  Thanks
« Last Edit: March 14, 2012, 08:15:45 PM by Cuda »
2011 Atomic  Silver
