Author Topic: Dyno Run today!  (Read 7616 times)
Offline GTRrob
Dyno Run today!
« on: May 19, 2011, 11:30:56 PM »
Had an opportunity to get my bike on a dyno today at a motorcycle event. One of the local dealers had one set up. Brothers from Bremerton if anyone is from Western WA. Anyhow, my bike had 1600 miles, KN air filter, PCV by Fuelmoto, Area P slip on (mid pipe and can), flyectomy. These mods produced 151 point something horsies. ;D Is this what other guys are seeing for power with these mods? I thought I would clear 155 HP. I guess that is for the fully piped...! ;) Torque wasn't provided and the graph is horsepower on the "y" and speed on the "x".
On another note, my HD put up 91 HP and 102 ft-lbs. Torque was provided for the HDs on the dyno because the operator placed a cable on the front cylinder spark plug wire. I don't know why that works. :-\
Also, the highest output bike put out 175 rear wheel HP! :o Newer ZX-14 with some mods...I didn't bother talking to the owner about the details.
Uglydog...where were ya?
Offline cutback
  • "Old enough to know better"
Re: Dyno Run today!
« Reply #1 on: May 20, 2011, 06:45:44 AM »
Good numbers Rob! 150+ HP on this bike, is gettin' after it. My ZX14 (EDR tuned) layed down 183HP, 109TQ. I'm hoping my connie will end up 150-160.
Re: Dyno Run today!
« Reply #2 on: May 20, 2011, 08:20:00 AM »
Rob, where were they setup?  Sorry I missed it, I woulda been there.
Chet
Re: Dyno Run today!
« Reply #3 on: May 20, 2011, 12:25:06 PM »
Post your dyno chart up on this other thread Rob, that way we can build on that thread with which mods produce what etc...  8)
http://zggtr.org/index.php?topic=312.msg2579#msg2579
Thanks.
Offline DocPigskin
  • I'm kind of a big deal
Re: Dyno Run today!
« Reply #4 on: May 20, 2011, 12:48:23 PM »
Wow!   183 hp!   Impressive.   I would realistically expect the Connie to be up around 155-160 hp with the correct mods (PCV, Full system, tuned, ect...).   I suppose it might get higher if you start losing weight in the wheels, factory exhaust, ect... but with average mods around that 150-160 hp
Re: Dyno Run today!
« Reply #5 on: May 20, 2011, 01:23:13 PM »
This engine is supposed to produce 155 HP at the crank but only 137 or so at the rear wheel. So I would think 151 at the rear wheel is doing pretty good.
Offline Tremainiac
Re: Dyno Run today!
« Reply #6 on: May 20, 2011, 01:54:39 PM »
Hope to find out tomorrow.
Local dealer has $5.00 dyno runs and free pizza.  8)
Offline Barry
Re: Dyno Run today!
« Reply #7 on: May 20, 2011, 03:16:12 PM »
Full Area P, PC-V, AutoTune, Filter, Flyectomy...  150hp on dyno.  Forget the brand.  Dyno type will yield different numbers.
IF you do a before/after, use same TYPE of dyno, and same dyno if possible.
Barry
Re: Dyno Run today!
« Reply #8 on: May 20, 2011, 04:35:23 PM »
Overall weight of the bike does not affect the horsepower.   It affects acceleration time, handling, braking, and fuel economy...
Re: Dyno Run today!
« Reply #9 on: May 20, 2011, 05:17:15 PM »
Those are awesome numbers, that shafty robs some power......interested to see what it would do with a chain.
Offline fmwhit
Re: Dyno Run today!
« Reply #10 on: May 20, 2011, 05:53:15 PM »
Free dyno runs at Moroney Cycles in Newburgh, NY tomorrow at their open house.  Sat. May 21.
Offline Shad0hawK
Re: Dyno Run today!
« Reply #11 on: May 20, 2011, 09:10:22 PM »
You are both right :)
Sort of, reducing unsprung weight has a greater effect on the bikes usuable power more so than simply reducing the weight.
Offline Barry
Re: Dyno Run today!
« Reply #12 on: May 21, 2011, 08:01:12 AM »
Actually, I believe it's unsprung ROTATING mass that would show up on a dyno.
Unsprung weight can be bad.
Unsprung rotating weight can be worse.
YMMV,
Barry
Offline soonerone
Re: Dyno Run today!
« Reply #13 on: May 21, 2011, 08:08:04 AM »
Barry
Same mod's for mine. 151.23hp...Didn't get to do a before....
Offline DocPigskin
Re: Dyno Run today!
« Reply #14 on: May 21, 2011, 08:36:17 AM »
 :grouphug:  Glad we can all get along  ;D
Offline Tremainiac
Re: Dyno Run today!
« Reply #15 on: May 21, 2011, 03:00:46 PM »
4th gear pull.
125.826 hp  :-[
Box stock with 1300 miles.
144 mph
« Last Edit: May 22, 2011, 03:53:11 PM by Tremainiac »
Offline Shad0hawK
Re: Dyno Run today!
« Reply #16 on: May 21, 2011, 03:57:45 PM »
YMMV,
Barry
Yes sir!
I forget the formula and after hitting some twisties I am too tired to google it  :D
Offline GTRrob
Re: Dyno Run today!
« Reply #17 on: May 22, 2011, 11:41:53 AM »
Chet
Set up at Keyport "Motorcycle Rodeo". Event is put together by the safety and cate fox people.
