Author Topic: Extra rear lights  (Read 5776 times)
Offline So Cal Joe
Extra rear lights
« on: March 05, 2012, 06:07:15 PM »
I know several here have used the whelem TIR 3 as an extra stop on your concours, here ius what looks to be the same light for $39.99, $10.00 cheaper than the whelen
http://www.galls.com/style-GR309-general_catalog-galls-surface-mount-led-lights
« Last Edit: March 06, 2012, 07:47:30 AM by So Cal Joe »
Offline BlkBird
Re: Extra rear lights
« Reply #1 on: March 05, 2012, 07:34:22 PM »
the link is inoperative.
Offline kawacop1642
Offline BlkBird
« Reply #3 on: March 05, 2012, 08:12:47 PM »
Try this link
Thanks
I'm leaning toward adding a flashing led brake (accessory) lamp as I tend to be a bit obsessive with hitting the brakes as people approach me to be sure they actually stop.
« Reply #4 on: March 05, 2012, 09:50:57 PM »
More expensive, but much larger, multifunction, easier to mount, and probably much higher quality:
http://www.zggtr.org/index.php?topic=2505
Offline So Cal Joe
« Reply #5 on: March 06, 2012, 07:49:39 AM »
This one I posted is made by Whelen, multi functional and the whelen one is one of the brightest ones around.
Galls Surface Mount LED Warning Lights are a big value in a tiny package! This compact surface mount / grille light provides flexible mounting options inside or outside your vehicle and delivers bright warning power day or night. Galls Surface Mount LED Warning Lights dramatically and discreetly increase the warning power of any vehicle.
Galls Surface Mount LED Warning Lights are moisture and vibration resistant with a built in flange for neat and easy installation. Compact size allows flexible mounting options inside or out. The Galls Surface Mount LED's 12 flash patterns can be synchronized for simultaneous or alternating patterns. Fits Whelen TIR3 mounting brackets.
Features:
•Moisture and vibration resistant
•12 flash patterns can be synchronized for simultaneous or alternating patterns
•5-Year Warranty
•1-1/8"H x 3-1/2"W x 1-1/4"D
•Built in flange for a neat and easy installation
•Fits Whelen TIR3 mounting brackets: GR196, GR195, GR212, GR260 and GR259
Offline 4cedars
« Reply #6 on: March 06, 2012, 09:07:19 AM »
When looking for additional rear brake lite I was ready to order one of these style liteheads also. I happened across a fellow LD rider who had the same unit and stood back while he applied the brakes. What I found, and he was already aware of, was that as long as you were directly inline with the litehead the effect was very good. But as soon as you started moving off center the effect started to diminish to the point of being no brighter than the standard bulbed taillite, especially in daylite, when the additional lite is more important to me.
So I started researching to find something that spread the light to the sides more. What I came up with was this,
http://www.strobesnmore.com/whelen-linz6-super-led-lighthead.html
It spreads the lite to the sides very well and is very easily seen during the daylite hours and is borderline obnoxious after the sun goes down.
I have this and the stock lite hooked to a wig-wag.
Just my .02,   John
IBA# 45862
MTF Tourers Assistant
« Reply #7 on: March 06, 2012, 04:18:37 PM »
Oh, it looked like some other brand.  Whelen is a very good/respected brand, indeed.  That still wouldn't do what I would want (and would still choose the Admore light bar in a heartbeat), but I can take back the "quality" comment, for sure.
« Reply #8 on: March 06, 2012, 04:20:07 PM »
That is actually extremely common with LED light fixtures.  Sometimes directionality is a good thing, but many times LED's are just too directional and need a good "diffuser" to make the viewing angle better.
« Reply #9 on: March 07, 2012, 01:01:41 PM »
Just my .02,   John
Those look pretty good, I've been looking for something like those to put low on my bags to compliment my other set-up.
Darknesses
« Reply #10 on: March 08, 2012, 06:37:46 PM »
I have the Whelen LIN3 mounted on the rear of my C-14 where the reflector was on the fender.  It definitely gets some attention.
Offline jqram35
  • 2012 C-14 Candy Arabian Red
« Reply #11 on: March 08, 2012, 08:24:15 PM »
I ordered a SoundOff GHOST LED Mini  EGHST1 today. Plan to mount it under the rack in the rear.
http://sirennet.com/soeghst1.html
Jeff
Offline OCK913
    • The Orlando Riders Club
« Reply #12 on: May 12, 2012, 02:00:58 PM »
I purchased one of the Gall's lights and installed it today. I have mixed feelings about it now that it is done. I mounted it to the black panel just below the OEM brake light and that panel has a little slope to it. That slope was just enough to reduce the brightness from OMG! bright to just everyday bright......at least during daytime hours. I will see what it looks like tonight and maybe that will be better.
            2009 Kawasaki C14 - Black
« Reply #13 on: May 12, 2012, 04:30:06 PM »
That's a shame, it appears you really did a top notch install. Very professional looking job from that picture. :thumbs:
« Reply #14 on: May 12, 2012, 10:29:20 PM »
 :thumbs: :thumbs:
