Author Topic: Power Commander Help  (Read 1699 times)
Offline schrader
« on: February 06, 2012, 10:44:53 AM »
Hey, I bought a used PC of a member on this site, when I hook it to the bike I get an F1 error. If I try to load new maps to the PC is says not communicating. Does the bike need to be running or just keyed on to install new maps? I am missing the 9V power cord so I can't do it that way.
Thanks
Corey
Re: Power Commander Help
« Reply #1 on: February 06, 2012, 10:47:19 AM »
Double check the ground.  I always have her running when I do MAP installs, I believe if it is a PCIII this is required, but I could be wrong.
Offline mcclaskeyj
  • Adventure...redefined
« Reply #2 on: February 06, 2012, 02:05:35 PM »
What model PC do you have? I have a PCV and it has a USB hookup to my computer. I am able to simply turn it on and load the map. You might want to ensure that you fit the connectors to your fuel injector input/output terminals good and tight. If they aren't securely connected you might also get the error you're seeing.
'83 C70 Honda Passport   '06 Honda Rebel 250
'76 Kawasaki KZ400          '79 Suzuki GS1000L
'04 Kawasaki Ninja 250     '07 C14 ABS  '09 C14 Red                            '08 CRF230L
http://www.bikepics.com/members/mcclaskeyj/
